master idle screw
master idle screw
Does the r1150r have one? If so where is it?
03 R1150R
2005 VW passat TDI
1995 Honda Odyssey
2005 VW passat TDI
1995 Honda Odyssey
bono, from your questions I'm assuming you have no manual. There is no master idle screw such as you'd find on carburetors. The bike is fuel injected and there twin throttle bodies. One on each side. These have to be synchronized at idle and at increased RPMs.
There is a really good tutorial on the ADVRicer forum and probably several discussions here some place if you can find them.
You'll need a TwinMax or other synchronizing tool to do this. But anyway, in the process of synchronizing at idle, you adjust the idle RPMs with the same Big Brass Bypass screws on each throttle body. It sounds more complicated than it really is.
Read up on TB synching in the other forums and it will get you much farther ahead than me trying to explain it here. If you can't find those articles then just ask here again and we'll work through it for you.
Chapters One and Two of do-it-yourself maintenance:
http://advwisdom.hogranch.com/Wisdom/OVADv2.2.pdf
http://advwisdom.hogranch.com/Wisdom/TBS4Dv1.0.pdf
jb
jb
I have average 12K miles / year.
Here' my tally:
Dealer ship Maint.
o $375 / 6K dealer maint service
o $425 per 12K maint. + yearly maint. service
Personal Maint.
o Oil(s) + filters : $100
Gas: I average about 35 MPG at ~$2.70/gallon (Califonia) $925 for gas
Tires 2 sets + mounting: $600
Average cost per mile:
o With Dealer service: $0.20 / mile
o With own service: $0.14 / mile
As a comparison: my car comsumes: 25 MPG
Cost of oil change: $100 (Benz, every 10K mi)
$0.12 / mile
Here' my tally:
Dealer ship Maint.
Personal Maint.
$0.12 / mile
Nobody is sure perfect, but she practiced tirelessly !
ProductUser
