New memeber - question about tyres (or is that tires!)
andy dodd
Post by andy dodd »
:D Greetings to all fellow R1150R riders!
After many months of viewing in lurk mode I decided it was time to join the fun!
Two questions;
1. Tyres. Can a 180 section tyre be fitted to the rear of the R1150R? The Rockster uses a 180 section and I would be suprised if it used a different drive/swing arm casting or wheel but I may (probably am) wrong. In the UK there is a far greater variety of 180 section rear tyres avaiable than 170.
2. Any other board members in the UK? If so do you ever gather for ride outs etc.?
Regards to all,
Andy Dodd
PS - Gas now $6.22 a (US) gallon over here!
Re: New memeber - question about tyres (or is that tires!)
andy dodd wrote::D Greetings to all fellow R1150R riders!
Two questions;
Regards to all,
Andy Dodd
The Rockster has a different rear wheel. ;) (from the R1100S Boxercup). See if you can find a 2nd hand one or if your dealer will sell you one if you really need it. But you should be able to find tyres if you look about.
Don't bother going for super modern rubber - Touring or Sport Touring tyres are very good on the "R" and they come in most sizes (Diablo Strada's, Z6's etc).
Leno
Post by Leno »
A lot of people use the Metzeler Z6 and find it very good on this bike. The Roadster does not need pure sport tyres. It does just fine on the Z6.
MIXR
Tyres
Post by MIXR »
Andy - The Rock uses a wider rim, hence the 180. Same fit up on the Roadster, but differing width rim. That said, you can fit a 180 profile on the stock Roadster rim (from most tyre manufacturers), but there is little point in doing so.
Leno is correct - Unless you are a serious track rider, the average sport/tour tyres work just fine on the R. Handling and suspension allow you to get all the way over quite safely, plus you get respectible life out of a set of bags.
I'm now on Avons and swear by them. The Z6 has a solid reputation amongst most users, but there are some chinks starting to come up here in Aus with life and 'funny' wear patterns, even on the rears. I have a feeling that many Z6 issues here may be due to a bad choice of tyre pressure rather than the tyre itself, but there are differing schools of thought on that as well.
As an aside, the Avon seems to be the 'widest' of the 170's. Beats me why. It only just clears the space and looks as wide as a mate's Rock with a 180 Z6.
jonothan
Post by jonothan »
Andy, I'm in Grimsby, North East Lincolnshire - where are you?
Jonothan
BMW R850R in silver
heated grips
panniers
flyscreen
cylinder head protectors
