Oil leak out filler cap
duegi
Post by duegi »
Changed oil and filter on '04 R1150R, 35K total miles. There is a bit of oil coming up through the filler cap over 3000 rpm. I'm guessing the cap, O-rings, etc. are just worn. Shouldn't be an oil overfill issue as the Clymer's manual called for 4 quarts with fluid and filter change. :doubt:
Brett
wncbmw
Re: Oil leak out filler cap
Post by wncbmw »
The first thing to attempt is to thoroughly clean all the surfaces on the o-ring and the filler cap gasket to see if that stops the problem. That used to work for me for a long time when I had the same issue.
When that no longer kept the oil from seeping out (and a little oil can look like a big mess!), I replaced the whole works at the next oil change. Not too hard to do and there is a description somewhere on this board. And the reason for the leak was obvious when I pulled the part out of the valve cover. The 'hidden' o-ring had completely disintegrated and was a gooey mess!
Easy fix. And the parts don't cost much. There are some cool after market options also, if you want to spend the money and do something different.
Vann - Lifer No. 295
Donating Member #: 312
Post by boxermania »
wncbmw +1
There are two portions with o-rings, the one inside the head and the cap. Sometimes the one inside the head becomes loose and needs to be removed, cleaned and re-installed.
challey
Donating Member #: 365
Post by challey »
I was always worried that the cheap and poorly designed OEM filler cap would fail on the road or that some malefactor would take it (or worse, dump something in and replace it). If the cap failed or went missing, you would be stranded until you could seal things up. And if someone decided to put something in the sump, there could be thousands of $'s of damage. So for peace of mind, I bit the bullet and replaced the OEM cap with the one from SW Moto. Though pricey (~$60), it is a much better design and tamper-resistant to boot.
http://www.moto-techniques.com/bmw.htm
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
duegi
Post by duegi »
I replaced the bottom piece and the two o-rings and reused the cap, see what happens this afternoon. Silly design but across the models the RT's would be a pain in the ass to add oil to with all the bloody plastic in the way, cie la vie.
If it fit I'd just get another right side valve cover and put it on the let jug and add oil somewhere on the block and be done with the leaking scenario. Although it was a cheap fix considering BMW parts.
Brett
sjbmw
Moderator
Donating Member #: 263
Post by sjbmw »
That plastic part has a life span much shorter than the bike.
I got one of these from my since departed dealer. Keylocked and worth it.
http://www.ascycles.com/detail.aspx?ID=33528
The BMW locking oil cap helps protect your engine from tampering.
Durable die-cast construction with a high gloss chrome plating adds an attractive accent to the left-hand cylinder.
A textured, non-coded polyamide key is included. The keyway is protected from dirt and moisture by a securely attached cover.
Serves as a direct replacement for stock filler plug 11 14 1 340 900, found on BMW 4-valve opposed twins from model year 1994 on.
duegi
Post by duegi »
Oil leak fixed, crisis averted, just hate loosing synthetic oil as it's so bloody expensive...
Brett
twindave
Donating Member #: 724
Post by twindave »
Here is what I use. Works great and looks great!
http://www.wunderlichamerica.com/motorc ... 00064.html
Know it, Love it, Ride it
