I need a new battery and I am not near a dealer, Is there any place to order them that does not charge an arm and leg to ship? Or there any alternitives out there?
jim
battery
thanks
Thanks that did not take long. i appreciate the info and timely reply
jim
jim
- Arbreacames
I highly recommend that you consider a drycell Odyssey battery. Just search for PC-680 on ebaymotors. They are $63.95 + $14 S&H.
Advantages: They don't require winter maintenance, they are shipped full and ready to install, they can be deep-discharged, they can be installed in any position except upside-down, and are supposed to last several times longer than a lead-acid battery.
Disadvantages: the terminals are oriented slightly differently, and you may have to make or buy a small angle bracket for the negative lead. Some install it on its side and claim they do not need the angle bracket.
Research it for yourself: there is plenty of information on the Odysser on the net.
Carlos D.
Odyssey is the way to go. You can probably bend your battery leads to work on the Odyssey as I did,
You can use your original battery charger to maintain the battery as well. Now if the battery is heavily discharged, you could use a cheap battery charger but be careful to time it. Information regarding charging is included with the battery. None of this is rocket science and the battery is a great bang for the buck (forgive the pun).
Another vote for the Odyssey PC-680
I went with the PC-680. I got it from Ebay. I think I paid $55 to my door for the battery. I actually ordered some battery terminal adapters for the battery so I wouldn't have to get into the bending issues but I do not remember where I got them from. I remember that they were not expensive.
I am not going to start a battery charging debate but I have been using my regular battery tender plus charger with my PC-680 for close to three years with no problems at all (knock on wood). Hope this info helps
