battery
jimed
battery
Post by jimed »
I need a new battery and I am not near a dealer, Is there any place to order them that does not charge an arm and leg to ship? Or there any alternitives out there?
jim
Boxer
Donating Member #: 2
Post by Boxer »
baltm604
Post by baltm604 »
bought the oem maint free from chicago bmw, just over 83 bucks out the door......
jimed
thanks
Post by jimed »
Thanks that did not take long. i appreciate the info and timely reply
jim
Arbreacames
Post by Arbreacames »
I highly recommend that you consider a drycell Odyssey battery. Just search for PC-680 on ebaymotors. They are $63.95 + $14 S&H.
Advantages: They don't require winter maintenance, they are shipped full and ready to install, they can be deep-discharged, they can be installed in any position except upside-down, and are supposed to last several times longer than a lead-acid battery.
Disadvantages: the terminals are oriented slightly differently, and you may have to make or buy a small angle bracket for the negative lead. Some install it on its side and claim they do not need the angle bracket.
Research it for yourself: there is plenty of information on the Odysser on the net.
Carlos D.
jamais
Post by jamais »
Odyssey is the way to go. You can probably bend your battery leads to work on the Odyssey as I did,
You can use your original battery charger to maintain the battery as well. Now if the battery is heavily discharged, you could use a cheap battery charger but be careful to time it. Information regarding charging is included with the battery. None of this is rocket science and the battery is a great bang for the buck (forgive the pun).
hotzuk
Another vote for the Odyssey PC-680
Post by hotzuk »
I went with the PC-680. I got it from Ebay. I think I paid $55 to my door for the battery. I actually ordered some battery terminal adapters for the battery so I wouldn't have to get into the bending issues but I do not remember where I got them from. I remember that they were not expensive.
I am not going to start a battery charging debate but I have been using my regular battery tender plus charger with my PC-680 for close to three years with no problems at all (knock on wood). Hope this info helps
