STAINLESS STEEL TIP FOR ROCKSTER
Green Hornet
Post by Green Hornet »
All
I finally found a place to make me 1 3/4" SS tips to replace muffler.
The company is http://www.stainlesssteelmufflers.com
They cost $60 a pair but now I have an extra or one to maybe sell.
Micky
2000 Moto Guzzi Jackal
2004 Rockster - Green
jfslater98
Donating Member #: 535
Re: STAINLESS STEEL TIP FOR ROCKSTER
Post by jfslater98 »
Hey Micky,
Let me know if you're interested in selling the other one, I'll buy it off you. Thanks.
FloridaBeakster
Post by FloridaBeakster »
I just got a chrome one for dirt cheap:
Chrome turn down tip
I did fit a piece of flat aluminum between the cat outlet and the tip to take up the small bit of difference in diameters.
-Mike
'02 R1150R
'88 R100RS
Green Hornet
I had one of those too. It is nearly impossible to keep tight and was almost completly rusted in 2 months. I am not trying to sell these myself just telling you will you not be happy with the one you ordered unless you live in "0" % humidity and have no salt within a hundred miles of you.
I live in Florida and when we get get bored we go outside and watch things rust.
:biggrin:
Cheers
:lol:
Micky
Micky
FloridaBeakster
To keep it tight, once it was all in place, I drilled a hole through one of the mounting holes through the cat outlet. I then ran a sheet metal screw with a wave lock washer in. I'm in the panhandle of Florida, so I have the humidity but not the salt spray you have. I'll let you know in a year or two how it's holding up.
-Mike
'02 R1150R
'88 R100RS
Beaze
Post by Beaze »
Wouldn't Locktite work just as well in keeping the bolts in? I know they make a high temp version (red) but it has to be heated to like 500 F to remove.... :shock:
Beaze
Post by Beaze »
Any chance of getting an audio/video clip of the bike running like that? Does it sound any different than running with the muffler off? (did this today when I put my Ohlins shocks on)
redline999
Post by redline999 »
I removed my exhaust and had a down tip like that for a while, but I started to get some lousy idle and stuttering on throttle. has anyone else experienced this? I replaced the old muffler and ,while quiet, the performance returned slowly over a couple of hundred miles, so I am drawn to conclude that the problem was related to the lack of back pressure, which I thought would be compensated for by the ignition computer. I thought that the cat would suffice, but apparently, in my case, it did not. any other experiences that did not work out just right? Thanks... :-k
NoRRmad
Donating Member #: 388
Post by NoRRmad »
Performance returned slowly, eh? Might have been the Motronic computer readjusting to the changed back pressure. Did you reset the Motronic when you installed the new tip?
redline999
Aha! reset the Motronic, eh? this is news to me. could you describe this process to me? I'd rather run well with just the down tip, if I could. No I did not reset anything, I just removed the muffler and added the tip....a bit cowboy, I see now. Thanks for your direction, I hope you can give me just a little more now.
HP
NoRRmad
Post by NoRRmad »
Switch the bike off, remove the seat and open the cover to the electrics box underneath
Remove fuse number 5 (fifth from the left,) for a few minutes.
Replace fuse number five, switch the bike on. (Do not start the bike.)
Twist the throttle, twice, from full-off to full-on. (this lets the Motronic know the range of voltages from the throttle position sensor.)
Close electrics box and replace seat.
Start up and ride away.
Hope this helps. [-o<
redline999
Thank you good sir, that is specifically, exactly what I needed to know. with simple directions and clarity. I will include your description every time someone mentions the exhaust conversion..... HP
NoRRmad
Post by NoRRmad »
Let us know if it helped run with the tip.
redline999
Tip installed, muffler gone (and 15 or so pounds) Motronic reset....runs like a top ! Thanks!!! It's a gorgeous sunny day in Seattle, and I don't think I can focus on work anymore...must go ride! Bye ! HP
NoRRmad
Post by NoRRmad »
And we just had a snowstorm. ](*,)
DAQ421
Post by DAQ421 »
I love this site.. I pulled the can and added a tip on my 04' R1150R and it was displaying similar issues as mentioned above. I was beginning to think I'd made a mistake and then I dug up this thread. Now, Motronic reset and the bike purrs.
I'd rather get heat rash than road rash. The end..
DAQ421
Post by DAQ421 »
On the topic of fuel air mix. After resetting the computer I'm getting a lot of popping on decel. Shouldn't the motronic reset cure this?
