Very happy with 117Bhp & 8600redline
Major Grunt 117Bhp anyone else?
Ride it like you stole it!!!
Bumblebee edition 80
Grunt
I've been hunting better fuel economy/performance for a while, & had a V hard look @ the new R12 engine, more Hp slightly lighter bike....Tripton wrote:Um.....
What?
So went back to the drawing board & up spec'd my engine.
Just wondered if anyone else had gone this far or further?
That horspower figure was from one cylinder only!!!!! That's why it managed to hit 8600 rpm.....see....
I once built a revolutionary single cylinder 10 liter displacement wooden engine....it ran very well and polluted little......mileage just kept getting worse. Sold it to Boxer as he intended to rebuild it....haven't heard anything since then......
cute.....
Hmmmm so only 1 other then....
the figure is from the dyno run....
And for those without a tree fetish...
New Engine,complete stripdown, balance & blueprint
new billet cams, new profiles, forged pistons, flow & port heads
remap ecu, larger injectors, ceramic clutch......
so pretty much the basics when I used to build race engines
zax1150
Ahhh so the truth finally comes out........your original post failed to mention any engine rebuild with performance parts.....
BTW, what clued you in, the seriousness of the responses?
Those are wonderfull numbers and you should be proud of them. Why don't you educate the lay users on the board and post the dyno graphs, along with everything that was done to the engine......
117 :D
Sorry 'bout the delay
just in the process of moving house, so very up on the air atm
I didn't chronograph what I did, but will organise pic's
I can suggest for the fiscally challenged,
DON'T! unless you have access to a race workshop eg: Nismo in my case
for those that want to play with a limited budget, 11:1 compression & a reasonable cam profile...will take you quite nicely to 95-100hp
Tuned headers make a decent contribution to hp
Goto http://www.wunderlich.de It's in German though...
They have lots of addon parts to increase horsepower. Cams, Chip, Exhaust...etc... Seems like they don't have these parts on offer in the States or in Greece.
Billy Rallis
http://www.greekmotoadventures.com
hydra
santa cruz bmw can get you just about any wunderlich part. just download the catalog and order the part # on SC BMW's site. i've only ordered the rockster "trimm" windshield and a couple non-performance parts for my BCR from them. but they have a bunch of performance parts for most beemers. i've been curious to know how well their parts integrate with our bikes. it would be awesome if someone can enlighten us...
here's the link for the catalog, then scroll down and find the one for the R1150R.
http://www.wunderlich.de/html/cat/eng/eng.html
here's the SC BMW link: click on the link "order by part #"
http://www.bmwsantacruz.com/Merchant2/m ... 50ROCKSTER
'04 boxer cup replika
'04 rockster
'04 rockster
Re: 117 :D
Hi there,zax1150 wrote:Sorry 'bout the delay
how do I get that extra compression? flow the headers?
Argh!
Sorry bout that we've been super busy
development never stops......
High comp is the easy bit , top end off an RS or RT as they run 11:3-1
the R/GS/Rockster only runs 10:3-1
that'll give you an easy 95hp .....
but if you want to twist the wrist heavily you'll need high lift cams & MOST important titanium push rods
that'll give you a comfort zone of 9000rpm red line
fuel pressure reg
BTW boxermania was right on the money
its a good idea to upgrade the fuel pressure reg, if you're on the hunt for performance
problem these days, is most manufacturers work to the absolute min requirements when chasing profit, so we end up with outcome of cost cutting.......like having a generic ecu with one profile for all the bikes
more power cap'n
.... Or get an R1150 RS.. 95bhp standard
Hughey
R1150 RS
Hughey
R1150 RS
hydra
Re: fuel pressure reg
hello zax1150,zax1150 wrote:BTW boxermania was right on the money
can you give me more info on the fuel pressure regulator?
do you mean installing one from a K12 or R12?
what size does the rockster have and what size would you recommend to give more HP?
would i need to intall larger FI's if replaced the FPR?
thanks
'04 rockster
'04 rockster
hydra
Re: bitz
hey zax1150,zax1150 wrote:Ok if you look back @ this thread you'll see the type of K Fuel reg
boxermania used, that'll do nicely, you can then look @ advancing the timing
i tried looking to see which FPR was in question but didn't find it. thanks for clarifying. so the 1150 has a 3.0 bar and the K12 a 3.5 bar regulator, right? can i get away with keeping my injectors? and i assume i'd have to change my mapping on my power commander??
San Jose BMW sells 12:1 pistons for the 1150R...
12:1 compression pistons for all R1150 motors and for our exclusive 1100-1150 conversion kit. NOTE: Pistons are sold as individuals, for a set order a quantity of 2. Price: $349.95
'04 rockster
'04 rockster
very good hydra
very good 3.5 bar makes a large difference kills the surge & supply problem & will keep good pressure @ the injectors when you need it most
it'll allow you a lot of leeway with performance mods
no you don't need to up the injectors unless you're going stage 3 & above
& no to changing your mapping (yet)
if you're going to 12:1 then get the high lift cams to suit...!!
the reason I suggested the RS/RT is you can pick up the parts cheap
& keep fairly bulletproof engine reliability.
although saying that,blueprinting is where I always start with an engine, brings it into spec.
Running 12:1 myself but thats with billet cams for my own profiles, larger sodium valves, flowed & ported the heads, forged pistons larger cap injectors & titanium push rods,
as a bonus you might remember that the ecu can be reprogrammed for 8 different profiles, thats why porsche' luv the motronic's so much
usually we keep access to the profile controls away from the drivers (they tend to fiddle
