R1150R Clutch bleeding nipple adapter How do I get one?
Not Dead Yet
Post by Not Dead Yet »
Just got my '04 Roadster and I've had my '00 R1200c for a couple of years. Both are due for clutch fluid replacement. Problem is the bleeder apparatus for the clutch requires an adapter nipple in order to properly bleed the system. A Mity-Vac won't connect or adapt without it. My BMW dealer in Spokane/Post Falls, WA. had no idea how to get one. I checked the service department and they said they lost thiers and have a jury rigged system for bleeding the clutch. Basically they said they can't help me without a part # which they could not find. Can you believe it!!!! Any suggestions on locating one. Who'd a thunk this would be a problem. :roll:
Boxer
Donating Member #: 2
Post by Boxer »
Part#: 34212330310
Part Name: Bleeder
Price: $7.03 in 2003 I think its $8 now
See:
http://home.mindspring.com/~jabrooks/te ... clerob.htm
BMWkidd
Post by BMWkidd »
This is what I did:
Replaced the factory bleed fitting with a Speed Bleeder SB1010
Note: the factory one is red loctited. Use flare nut wrench if possible.
Lifer #276.
ruddy
Post by ruddy »
It looks like you used an adapter in the photo. What exactly did you have to do in order to install the Speed Bleeder?
Thanks.
Rick
2003 R1150R: Silver
Lifetime Member #585
Not Dead Yet
Excellent response boys :D. I'll recommend this site to my local dealership....it seems they could use a little help now and then!
iowabeakster
Post by iowabeakster »
how in the world does a dealer not know how to bleed the clutch? so much for holding the dealerships to high standards.
