I like to ride a great many different road conditions gravel to highway, but mostly W.Va. twisties. What are the options and pros and cons to the various units. BTW I don't need more power, noisier exhaust or anything else so I thought I tune the suspension.
Aftermarket shocks
Aftermarket shocks
Having solved the ergonomic issues seat footpegs and barbacks I am thinking the shocks should be renewed 26,000 on the clock. While they are OK I feel that a better set would improve the already great handling.
Michael
MG 78 LeMans
78 R100S
MG 78 LeMans
78 R100S
beemer-biker
Ohlins, Wilburs, Works, Performance......All great brand aftermarket shocks. I've asked this before, which one has the best bang-for-the-buck factor? They are all over $1000 for a pair (a serious investment) and we hear they are all recommended. Can anyone explain WHY Wilburs is better than Works, or Ohlins is better than Performance? THE brand we are all familiar with is Ohlins, and most of us have heard of the others but I don't think ANYONE has tried multiple brands on the same bike to see the differences.
Anyone? ANYONE? I may soon research this with serious intent since my bike has just over 43k miles. I would like to have a new set of shocks installed and sorted out by next spring (so I can try and keep up with CycleRob at the next bash).
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
beemerphile
It is hard to evaluate since, as you noted, not many people have direct experience with multiple brands on the same bike. You can, however, note the relative satisfaction level, price, and service/rebuild issues.R4R&R wrote: Can anyone explain WHY Wilburs is better than Works, or Ohlins is better than Performance?
In my limited study, someone who had tried both said that Wilbers were a little better than Ohlins for a little less money and rebuilds through the New Jersey outlet were painless and quick. In ordering my Wilbers, I'd also add that Klaus did a wonderful job of fitting the spring rates to my intended use. I never have to fiddle with preload. I don't sense that the assistance is there with Ohlins to truly fit them to you and your loading/use of the bike.
I am sure the other brands are fine and there is probably no wrong answer to the question, but I am 100% satisfied with the Wilbers and the service I got through the New Jersey office. I have heard they are trying to sell direct now, but I can't imagine why...
http://wilbersusa.com/wilbers/Products/prodShocks.htm
Thanks for the input. This thread was prompted when I went into a tight turn and at the apex there was a patch in the road, from one side to the other about a foot wide. Well we got through it only scared to death, but the worst part was that the Yamaha V Star I was following, never skipped a beat.
This bike is as good a handler as my MG LM1 but not as good as my old Ducati, I lust after that kind of handling! Can that Happen or am I kidding myself?
Michael
MG 78 LeMans
78 R100S
MG 78 LeMans
78 R100S
Panzerleder
The Roadster is a GREAT handler, but will probably never be as good as any Ducati no matter what you put on it. After all, handling is Ducati's raison d'etre. Some bikes are all about style and noise (HD), others are known for more performance than any sane person can use (Kasuki), and some, like BMW are just great all-arounders. Tires make a lot of difference (more so than shocks), but I have found that the rider, not the bike, makes all the difference in the world.
Were you 'holding' the tank with your legs/knees, weight off the bars with your arms loose? The roadster should've been able to soak that patch up. Maybe check all aspects of your suspension - maybe something is loose. Also check tire pressure; what condition are your tires in? I notice a big difference in my bike's handling when going from old squared off tires to fresh tires.
I think I'll ask for new shocks for my b-day and see what happens.
So I got a quote back from Wilburs:
That's still a lot of $$$!Front:
Model 630 @ $ 487.00
the shock has adjustable rebound damping with 22 clicks, and infinite variable adjustment for the spring pre-load via C-spanner
Rear:
Model 640 @ $ 516.00
as above
or:
Model 641 @ $ 798.00
the shock has adjustable rebound damping with 22 clicks, as well as High and Low speed compression damping with 22 clicks and hose mounted reservoir.
Options:
# 629 = infinite variable adjustable ride height +/- 1/2" for either model front or back $ 78.00
# 625 = hydraulic pre-load adjuster for rear shock, to eliminate the fiddling with the hook-wrench @ $ 211.00
Panzerleder
Aftermarket Shocks
The prices on the wilbers are about the same as Ohlins when equipped the same. The front w/ length adjustment and the rear with the adjustable preload. As far as the remote adjustment for high/low speed nice bling but not something that would be used much once dialed in. My previous bike an F650 I did the suspension (Race Tech Gold Valves in the forks and a Ohlins rear shock) and I wish the R1150R rode as nice. It is the only other thing I want for the R.
P Jensen
14 R1200R
Montego Blue
NW VT USA
14 R1200R
Montego Blue
NW VT USA
I haven't made the decision yet. Nor gotten the approval.Panzerleder wrote:John - When you get 'em, let us know how you like them!
I'm going to price out the major brands to see the exact difference. It sounds like Wilburs would pretty much custom build the shock for ME, not 'adjust' it. They sounded willing to please which goes a long way.
Panzerleder
Panzerleder
Good idea! I'm probably in for something. Here's the web site for Works Performance. It looks like their front shock for the R1150R is $419 and the rear $589.
http://www.worksperformance.com/html/bmw.html
