Tires cupping! What's up with that?
wsmac1150r
Post by wsmac1150r »
Wow...I love the great feedback I get on this forum! Here's another one for you. Why are my tires cupping? I just got the bike a couple of weeks ago...tires have lots of tread. Pressure was about 5 lbs low on both tires when I bought it...don't know how long he rode it with low pressure or if that could have caused it...I've got them at factory specs now.
The next question is, are they safe to drive on?
Another interesting thing is that at low speeds, like turning in a parking lot on smooth concrete, they make a rumbling noise and you can feel them...like I'm rolling over a rough surface. This does not seem normal to me either...
I ride, therefore I am.
** 2002 R1150R **
DJ Downunder
Post by DJ Downunder »
I think cupping is just one of those things that some tires do as they wear.
The rear squares off..the front cups....correct tire pressure can help a little.
Some brands or tire pattens do it more that others.
My original Macadams or whatever they were called cupped really bad.
My last two sets of Pirelli's have not cupped much at all.
I think it's caused by braking...I remember when I used to ride on the road with knobbie tires on my old trail bikes the front knobs would wear at an angle..so I think it's caused by the tread flexing and wearing at an angle while braking.
It's just my opinion... :D
DJ
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
While I am not the expert, I can tell you these things from across the BMW board universe with respect to cupping:
Telelever tends to cup tires due to the way the road surface oscillations are transmitted back down into the wheel/tire from the upper member. The forks are more isolated and this is different than conventional front suspension oscillations.
Bridgestones seem to be the most susceptible to cupping.
Hard tires tend to cup more than soft tires (compound not pressure).
Low pressure definitely is the primary factor in a particular cupping incident.
HTH
taosports
Post by taosports »
Mike and DJ are both correct. More info here :
http://www.rattlebars.com/valkfaq/tirewear/#CUPPING
R4R&R
Donating Member #: 293
Post by R4R&R »
I've seen Dunlops cup on non-BMW bikes too. My previous Suzuki would reliably cup the front Dunlop, and it didn't matter which type of tire I had; sport or sport-touring. What I've noticed on my R is that Metzelers don't noticeably cup (Z4 and Z6) compared to the Dunlops.
I currently have Avons on it now and they're pretty worn out. While the front looks normal (besides the left side wearing more than the right), my rear tire has cupped! I think it has a lot to do with tread pattern and riding style. Tire pressure plays into it too but I think if a certain tire is prone to cupping, there isn't much that will stop it.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
R4R&R
Post by R4R&R »
taosports wrote:Mike and DJ are both correct. More info here :
Wow - what a great website! That explains cupping AND the uneven wear.
Ed K
Post by Ed K »
From the article that Tao posted...
The softer the compound of the tire, the sooner this cupping will develop. Radial tires are more prone to cupping than are bias ply because the compound of radials is softer.
From MikeCam...
From R4R&R...
Regarding above, I've gone through several sets of Z6s, and now am running Pilot Roads. The Pilot Roads are more compliant (softer), and I find they cup much less than the Z6s under identical conditions. In fact, the PRs are much better tire for the R1150R (IMHO).
From DJ...
Agree... correct pressure will help, but not eliminate cupping... especially if you are an assertive rider.
Regarding tire pressure... a while back MIXR recommended to me in similar post to try 36F / 42R. That can be a bit hard for some riders, but over the years, I have found that to be best for my style as well.
Ed K
07 K1200S
Lifetime Member
MikeCam
Post by MikeCam »
Don't you lov e the 'net.
In my experience and observations, harder tires cup more frequently and severely.
The article states an opposite view.
Biff's R
Donating Member #: 289
Post by Biff's R »
I think that tread pattern has an important part in how a tire wears. The original Michelin Macadam front cupped/scalloped badly at 5k miles, but the Pilot Roads with an entirely different pattern have not cupped in the 8k+ miles I have on them.
I liked the Metzeler z4 better than the z6, but since they no longer make the z4 I switched to the Pilot Roads(also with Dean's recommendation).
Look at the Difference in the front tires. The rear tires are pretty similar to each other.
http://two-wheels.michelin.com/2w/front ... 44&lang=EN
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
DJ Downunder
I agree.
This tread = lots'a cuppin' (my old Macadams)
http://two-wheels.michelin.com/2w/Image ... eSite=LP2R
This tread = not much cuppin' goin' on here.
I don't think a full slick would cup at all.
Am I barking up the wrong tree here?.. :D
DJ
owldaddy
Post by owldaddy »
I think your right DJ, tread has a lot to do with cupping, and in fact, I have never seen slicks cup, they will lose big chunks of rubber when hot, I think that has more to do with the soft compounds on slicks.
Don
challey
Donating Member #: 365
Post by challey »
The front of the Dunlops on my R from the factory was noticably cupping at 4k mi and got replaced by Z6s at about 7k. The Z6 looks like it's just starting to cup at the 8k mark. Projecting from the Dunlops, that would mean I'd be replacing them due to cupping in another 6k miles.
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
