Gas milage
Posted: Tue Aug 01, 2006 12:45 pm
by rock712
Ok,
I know this bad been brought up before but I have been methodically monitering my milage and this is what I have been getting:
Highway travelling 75-85 mph
100miles (on the odo) = 2.5 gallons
40.0 MPG
City stop and go
100miles (on the odo) = 2.9 gallons
34.4 MPG
What I'm asking is anyone else get these numbers?
Posted: Tue Aug 01, 2006 2:08 pm
by jas
I only have about 5000 mile thus far, but I average 45 mpg. I ride 120 miles a day 6 days a week at a range of 65-85 mph. The more miles I put on the bike the better mileage I get.
Re: Gas milage
Posted: Tue Aug 01, 2006 3:15 pm
by Deano
rock712 wrote:Ok,
40.0 MPG
City stop and go
34.4 MPG
Sounds pretty close to what I get.
Re: Gas milage
Posted: Tue Aug 01, 2006 3:29 pm
by thenewcamus
rock712 wrote:Ok,
40.0 MPG
City stop and go
34.4 MPG
same or worse for me, I have a small problem with keeping the bike under 90mph
I have never gotten better than low 40's on a tank of gas, even when being "good".
Posted: Tue Aug 01, 2006 4:08 pm
by rock712
My bike has 15,000 miles and the can off........I'll keep tabs on it
Posted: Tue Aug 01, 2006 4:37 pm
by NoRRmad
I don't ride in The City -- except to get out of it -- but on the highway at 65-70 MPH, I get 4.2 gallons fill-up every 210 miles. Works out to 50 MPG.
(Oh, I'm riding a Roadster, not a Rockster.)
Posted: Thu Aug 03, 2006 9:12 am
by r1150rr
40 mph +or- 2 mph
Posted: Thu Aug 03, 2006 9:41 am
by NHighCotton
45-47 mpg mixed highway and city. Stock bike with sport shield, 12K miles.
Haven't ran it long enough with bags on it but, I suspect it would be lower.
Posted: Thu Aug 03, 2006 11:16 am
by rearro
Wow :!: you guys get good gas mileage last time I filled up I read 152 on the trip guage and it filled up with 4.2 gal. so I'm only getting 36 miles to the gallon. I ride with saddle bags most if the time and my rock only has 3800 miles on it, I wonder if that makes a difference? I usually shift at about 4k rpm is that when you guys shift? or am I shifting too late and consuming more gas that I should?
Posted: Thu Aug 03, 2006 1:39 pm
by OneShot
I usually shift between 5k and 6k. I fill up at ~165 miles and average 44 mpg city/hwy.
Cheers!
Posted: Thu Aug 03, 2006 2:08 pm
by beemerphile
On my recent 4,000 mile trip I averaged 47 MPG when the average speed was over 70 MPH and 50 MPG when the average speed was under 70 MPH. Mileage didn't go much over 50 even when the speeds averaged 60 MPH. I used my GPS to keep track on average speeds per tank. In city driving I get about 45 MPG since I took the Techlusion R259 off of it. With the Techlusion installed I was at 40-42 MPG.
Posted: Thu Aug 03, 2006 3:21 pm
by NoRRmad
My figures (~50 MPG) are pretty well fully loaded. I usually travel with panniers, tank bag, and three rolls -- thermarest mattress, camp chair and tent -- strapped across the rear seat (though I removed the seat and put on the silver BMW cover plate...) I use the Sport Shield and shift pretty short. I'm easy on the throttle, except when passing. I think the Sport Shield helps a lot.
Posted: Fri Aug 04, 2006 9:04 am
by r1150rr
I wonder if rocks get lower millage? Mine is in the 40mpg range.
Beak vs Rock
Posted: Fri Aug 04, 2006 9:58 am
by bad n ruin
Not sure, but I think rocks don't have the Roadster's(US) overdrive sixth? My Roadster averages ~ 45 mpg in mixed.
Posted: Fri Aug 04, 2006 3:31 pm
by NoRRmad
Ah. Good point. I do have the overdrive 6th. 3500 RPM at 70 MPH indicated -- which I think is 63 actual.
Posted: Fri Aug 04, 2006 5:38 pm
by dhfriday
I've only calculated mine once, but I got 45 mpg too. My can is out, and i've got no bags. Any tips on improving?
Re: Beak vs Rock
Posted: Sun Aug 06, 2006 9:53 am
by Lion_Lady
Rocksters have overdrive. The other thing that is likely to effect mileage is that the Rock doesn't come with a windscreen.
I've got the OEM screen which is pretty tall, and I average between 44-46 mpg. I get better if I'm doing straight highway.
I keep rpms at around 4K give or take a couple when 'just going.' OF course in 6th at 70+ mph it creeps up to 4500 and more. Sounds like you guys are riding your beemers like jap bikes: high rpms.
P
Posted: Sun Aug 06, 2006 10:59 pm
by rock712
Yep I'm revving mine........
Posted: Fri Aug 11, 2006 3:13 pm
by chris
I fill up at around 185 miles and it usually takes 3.5 gallons which is around 52mpg.
Posted: Sun Aug 13, 2006 6:22 pm
by Fivetide
I ran out at exactly 160 miles,luckily at the top of a downhill dual carriageway exit ramp;with a sainsburys garage at the bottom.Phew!only managed to get 18.5ltrs in to the tank,which i think works out to around 40mpg.mainly dual carriageway,with some urban and country A roads.only had my rock '03 80th edition for a few weeks,but lovin it!going to try and curb my enthusiasm a little,and try to improve the fuel consumption.mine came with remus 'Y'pipe and revolution end can.Do any of you think thiscould have a negative affect on consumption?
