TonyT607
Posted: Thu Feb 23, 2006 9:02 am Post subject: Givi V46
Chant, I think the BMW softcase (really marketed for the K12RS) is kinda useless. I separated mine from its mount (that locking plastic plate) and bolted a Givi V46 to it. Looks great, and I can secure/unsecure to/from the bike it with my ignition key. I just didn't like the looks of the Givi plate.
I have done long tours with the Givi (includnig the MOA last year) at up to 100 MPH with no problems. Totally waterproof. I picked the case up from Happy Trails last summer for $215. I use it instead of the BMW cases for my everyday errands, supermarket, work commute, etc
Check out my Smugmug gallery for more pics:
http://r1150r.smugmug.com/gallery/179358/3/27805103
PM me if you have questions.
_________________
Tony
05 R1200ST
Dark Graphite Metallic/Sydney Blue Metallic
Lifetime #156
I used the stock mounting for the soft case and attached it as TonyT607 did on his old R1150R, but I noticed he beefed up the silver plastic rear shelf with a Pirate's Lair bracket for mounting the Sargeant made passenger back rest. Not cheap but adds loads of flexibility, and easy changeability. This allows me to use my stock BMW ignition key to easily remove the case for a stock appearing look, and for riding 2 up with the passenger back rest, when needed. In order to mount the Pirates Lair bracket to accomidate the BMW mounting bracket, you must separate the Pirates Lair bracket away from the silver stock shelf by adding some stainless steel washers. It works great, is solid and I have great flexibility. Check out Tony's link to his pictures.
Rob
