Final drive bearings
The rear wheel is definitely moving relative to the final drive box.
Bah!
Do I need special tools for a full bearing and seals swap?
I've never done this particular job before.
Bah!
UberZogster
Re: Final drive bearings
I just got the main bearing for my r1100s and haven't needed anything special so far. All I've done is take the easy bits apart though. I talked to the shop and they said all you need is a press for the main bearing. My other bearings look good so I'm leaving them alone. The drive shaft seal is leaking a bit so I plan on replacing it too.
BadToTheBown
I thought this was pretty good - http://forums.pelicanparts.com/bmw-r110 ... ement.html
Some have used and oven to get the bearing on, freeze for the other part, said bearing just about dropped on, this one does all the rear suspension bearings - https://advrider.com/f/threads/shade-tr ... nt.234400/
BadToTheBown wrote:I thought this was pretty good - http://forums.pelicanparts.com/bmw-r110 ... ement.html
This!
mike Mojave CA
'04 ROCKSTER
'04 ROCKSTER
On closer inspection.... It's BOTH a weeping crown gear seal, AND the pivot bearings. So it's going to be a full monty change EVERYTHING job.....
Just what I didn't need this month.
How many miles on your machine?
On another note......I looked a bit thru "A Rockster Life". Incredible photos, and such beauty and history. I can't imagine what it's like to
travel where you have.
48,000, it's an '03towerworker wrote:How many miles on your machine?
Thanks, i was lucky with certain life circumstances. But travel isn't hard, and beauty can be just around the corner of you keep your eyes open.On another note......I looked a bit thru "A Rockster Life". Incredible photos, and such beauty and history. I can't imagine what it's like to
I haven't even travelled that far, just South Western Europe. Thats a tiny part of the world in reality
Thanks Towerworker and Riceburner. I did not realise that clicking that link would open up anything, never mind those fantastic photo albums.
As a random comment, I have visited the Massif Central- Mont Dore area on a camping holiday. A round of the European Speed Hill Climb championship was on and I spent a day watching the cars on the long 10k? climb.
I had that final drive bearing done by a main dealer, cost several hundred pounds iirc. A big saving to DIY .
gregor wrote:Thanks Towerworker and Riceburner. I did not realise that clicking that link would open up anything, never mind those fantastic photo albums.
I would do it myself, but I've not got a huge amount of mental space at the moment, nor the confidence in my own ability (I don't like messing with bearings). Imo a good mechanic knows when to get help in.
i beat my crown gear bearing off with a claw hammer and a cats claw.
then froze the bearing and baked the gear, slipped almost all the way on, and did a little tap tap with the inner race from the cratered unit
2002R1150R ABS Misty Blue 48K
I recently discovered a nearly imperceptable bit of play in my rear wheel. A couple of suggestions from some members sent me on a research frenzy where I found these very interesting pieces of information. I bought a couple of standard tools to make the adjustment to the pivot bearing and if that addresses the problem, I will then order the Emerald bushing set to replace the bearings. If not I will remove the drive unit and take it to San Jose to swap for a rebuilt unit..... or I know a machine shop that might do it for me.
https://www.beemershop.com/Merchant5/me ... e=TRA11094
https://www.youtube.com/watch?v=WBt6ftaJ_0s
https://www.youtube.com/watch?v=L0_j8SuiFQI
There is also a UTube on rebuilding the final drive, but, Chris recommends against that to reduce stress and frustration. Apparantly it's a real pain in the area your seat is responsible for.
2004 R1150R - Mad Maxine
Nuevo Arenal, Costa Rica
i wound up using a cat's claw (carpenter nail extractor) to remove my fragged bearing from the crown gear.
that was special
that was special
I used a HF puller to get mine off. I don’t recall it being too bad. Have used on other things doing car repair since then. I only had to replace the crown ring bearing. My only concern with my repair is that I just used the spacers that were already in it. The procedure to get the perfect height with my home tools was not in the cards. Hopefully the factory height was not the issue.
2003 R1150R
1991 Honda Nighthawk CB250 !!
