I installed a turn signal auto-cancelling unit called the "Smart Turn System"
https://www.safer-turn.com/us/
Some Specifications (from the website):
Unit dimensions: 32x32x45 mm
Unit weight: 155 g
Housing: Reinforced automotive-grade polyamide
Power supply: 12 VDC
Consumption: 250 mW
Cable length: 50 cm
Manufactured and shipped from Slovenia.
It is a small plastic unit that is mounted on the bike, and "spliced" into the wires coming from the L and R turn signal light, the reset wire, and is powered and grounded. The unit supposedly contains a few motion sensors and can sense when the bike is moving, stopping, leaning or un-leaning and will turn off the signal at the correct time. Also self-cancels after 15 sec if no turn is initiated. In operation, when the key is turned to ignition, there will be a single R flash followed by a L flash indicating that the system is calibrating. Then you're supposed to be good to go.
The issue I am having is as follows:
Every time I turn the key to ignition I DO get the single R and L flash. However after starting the bike up, I get NO turn signal response when I try to activate either signal (OBVIOUSLY NOT A GOOD THING). However after riding for a period of time and coming to a complete stop, the unit will suddenly spontaneously recalibrate (single R and L flash) and then operate like a dream until I turn the bike off. Then, usually it will take a much shorter time to recalibrate after starting the bike again.
A bit more info:
- I have the unit powered via a relayed fuse panel (10 amp fuse) which also powers a few accessory lights that work great (I have tried various different connections on the panel).
- The unit NEVER recalibrates while moving. I could ride from Providence RI to Connecticut and it will not work until I stop for gas (BUT then I have to turn off the bike again - NO SIGNALS!!!)
- The customer service has been great. The support staff - Mark - has answered tons of questions and even sent me a replacement unit free of charge thinking there was something wrong with the first unit. He insists that this unit is compatible with the 02R and has installed some himself on this model. I have no great reason not to believe him. He is stumped by my issue.
- I was due for a new battery anyway, so I just replaced it. If anything, seems to take longer for the unit to come on since installing the battery...
I know this is a big ask, but I really love this unit when it works and would love to get it to work right before finally throwing in the towel. Wondering if there is something obvious/specific that I am not thinking about....something electical? voltage? power source?
Any help would be great. If ahy additional info would help let me know.
Help me Obi Wan Kenobi - you're my only hope!
Steven
