Noisy airfilterbox
Noisy airfilterbox
Do you have this problem? I think my airfilterbox create irinoing noise at 2000-2500 rpm.
Re: Noisy airfilterbox
The first step is to check if all the intake components and the filter are there. Also check if the oil drain plug (above the rear suspension pre set) is present. My bike is standard and the intake only makes a pleasant mild bellow when accelerating hard AFAIK.
Yes! I'm often tempted to stuff the box with sound dampening foam to see if that helps. I'll look into what gregor wrote though...Torsen wrote:Do you have this problem? I think my airfilterbox create irinoing noise at 2000-2500 rpm.
2003 R1150R
2007 DL650 "weeStrom"
SteveJJ wrote:Yes! I'm often tempted to stuff the box with sound dampening foam to see if that helps. I'll look into what gregor wrote though...Torsen wrote:Do you have this problem? I think my airfilterbox create irinoing noise at 2000-2500 rpm.
LOL
that would do it. hard to be loud when it wont run!
its loud because its right under your left knee. with no barrier. deal with it.
