I just got back from a 4 day trip from Akron, Ohio thru West Virginia and Virginia. At the end of the second day I noticed some slight surging while the bike was powering up thru second gear. At first I thought the clutch was slipping. As the day went on on it got worse to where the bike would surge rather hard only when the bike was under a load, going up hill or pulling hard out of any gear. If the bike was not being pushed hard it was OK. The idle is rough. I first though I got some bad gas so I went to the auto parts store and got some fuel treatment and put it in the tank. It did not help. I ran the tank of fuel down to 1/4 tank put in new gas did not help. I went thru 3 or 4 tanks of gas getting home and it is still surging under load. I tried to take it easy getting home. When the bike would start to surge I would back of the throttle and it would stop surging.
The bike is a 2008 R1200R with 40,000 miles. I am going to hook it up to the GS-911 to see if there is anything to see. I am thinking oxygen sensor, stick coil, spark plug. Any suggestions? Any help would be great.
Roger L
Motor "surging" under load
Re: Motor "surging" under load
I just hooked up the GS-911 and there are no fault codes. I did a graph of the oxygen sensors and they look to be OK as well. That leaves the stick coils. Any other suggestions?
Roger L
Roger L
I took out all of the spark plugs and the (2) primary spark plugs looked nice. The (2) secondary plugs looked rich and had some light carbon deposits on them. I replaced all of the plugs with plugs that i took out at 20,000 miles. I took the bike for out for a ride ant it was MUCH better but there was still some hesitation under hard acceleration.
I ordered new spark plugs. I think it is a coil that is bad but which one? I one secondary coil was bad could this cause the problem?
Roger L
Roger L
Does sound like a spark failure when cylinder pressures are high...could be plugs, coils or spark plug wires. With coil on plug...coils sound suspect.
Red 2011 R1200R
Blue 1986 K75C
Steel Grey 2002 M Coupe
Blue 1986 K75C
Roger,
Can you do a screen capture of the O2 plots? The symptoms you're describing sound like a worse case of what I've had when a sensor fails (and both of mine have needed replacement.)
Don:
I will do a screen capture tonight. I swapped the spark plugs to the ones I took out at 20,000 miles and rode the bike to work today. Normally I ride in 6th gear at 4,000 RPM on the freeway. I could not keep the bike in 6th gear because of the hesitation. The engine ran OK at 4,200 RPM in 5th gear.
I have a friend with a R1200GS that will let me borrow (2) coils to see if that solves the problem. I will get them Thursday night.
Roger L
Roger L
Don
I sent you a E-Mail with some screen captures of the oxygen sensors. They look very much like the one you posted in the rough idling thread a while back.
Roger L
Roger L
I borrowed some coils from a friend with a GS and started swapping out coils one at a time to see if I could isolate the problem. I found the primary coil on the left cylinder to be causing the problem. With the borrowed coil in the bike it is back to full power with no hesitation. I will get a new primary coil and I should be good to go. I am also changing the spark plugs while I am at it.
Roger L
Roger L
