Anybody know how to get things back to normal? Thanks.
Fuel Info replaced by Trip/Odometer Readings!
carlmunger
- websterize
Re: Fuel Info replaced by Trip/Odometer Readings!
If removing the power doesn't reset it, you might try holding the two buttons in again, in the hope you can somehow repeat the sequence that got them reversed. If that doesn't work, schedule a dealer reset. But what they'd charge is probably even more aggravating.
I don't have anything to suggest beyond what Bill offered. But I'm interested in how this turns out. Please let us know if you're able to re(mis)program the buttons, or what result you obtain if the bike is offered to a dealer for repair.
David Brick
Santa Cruz CA
Santa Cruz CA
tinytrains
The instrument cluster has some undocumented features as you have found. You found the stopwatch/lap timer feature. As I recall, holding the buttons down should return you to the right mode.
It is detailed in the F800GS manual (same cluster). I don't know why they left it of the R12 manual.
http://www.motorpdf.com/bmw/bmw-f800st-owners-manuals/
Stopwatch
As an alternative to the odometer, the stopwatch 1 can be displayed. The display consists of hours, minutes, seconds and tenths of a second separated by dots. In enable improved operation of the stopwatch while driving (as a lap timer), the functions of the button 2 and the functions of the INFO button on the handlebar can be interchanged. The stopwatch and the odometer are then operated with the INFO button;
the onboard computer must be operated with the button 2. The stopwatch continues to run in the background when the display is temporarily switched over to the odometer. The stopwatch also continues to run when the ignition is temporarily switched off.
Operating stopwatch If necessary, switch over from odometer to stopwatch with button 1.
With stopwatch stopped, press button 2 to start stopwatch.
With stopwatch running, press button 2 to stop stopwatch.
Press and hold button 2 to reset stopwatch.
Stopwatch shows
0.00.00.0
Interchanging button functions
Press and hold button 1 and button 2 simultaneously until display changes.
FLASH (engine speed warning indicator) and ON or OFF are shown.
Press button 2.
LAP (Lap-Timer) and ON or OFF are shown.
Press button 1 repeatedly until desired state is shown.
ON: Operation of stopwatch with INFO button on handlebar fitting.
OFF: operation of stopwatch with button 2 in instrument cluster.
To save the setting made, press and hold button 1 and button 2 simultaneously until the display changes.
Stopwatch
Stopwatch shows
0.00.00.0
Press button 2.
Scott Schifer, Torrance CA.
1988 K75 Low Seat
2009 R1200R
1988 K75 Low Seat
2009 R1200R
VERY cool Scott..
Can't imagine why I'd want to do this, but good to know I can do it (or undo it if done by accident..)
Thanks much!
Thanks much!
I read it a few times. I see why its not in the owners manual, I still can't commit it to memory.
Thank you, a good discovery about my own bike.
Thank you.
David
Thank you.
David
tinytrains wrote:The instrument cluster has some undocumented features as you have found. You found the stopwatch/lap timer feature. As I recall, holding the buttons down should return you to the right mode.
Stopwatch
Stopwatch shows
0.00.00.0
Press button 2.
tinytrains
This came up either here or the MOA board a couple years ago. Someone had discovered the lap timer by accident. Of course I had to try it had the same problem. Fortunately someone else knew about the F800 manual and saved the day.
Happy to help.
Happy to help.
1988 K75 Low Seat
2009 R1200R
1988 K75 Low Seat
2009 R1200R
I acknowledge the functionality - 'tho I've never used nor expect to use it - but golly gee: the manual is just terrible writing. I know BMW isn't usually ashamed about anything, but they ought to be ashamed of that.
David Brick
Santa Cruz CA
Santa Cruz CA
carlmunger
Re: Fuel Info replaced by Trip/Odometer Readings! - Fixed
carlmunger
TINYBRAINS ------ I like that , looks like someone has a new name on the list. Thanks to Mr. Munger
tinytrains
1988 K75 Low Seat
2009 R1200R
1988 K75 Low Seat
2009 R1200R
A little off subject here -- but it's winter time.
That picture of the two story barracks building looks horribly familiar.
Are those all N scale trains. If they are the detail is fantastic, if fact if they are HO they are fantastic. Great layout, gets me to thinking about breaking out my old N gage stuff and doing something with it. It would keep me off the keyboard in the winter time.191387484
