What you need;
1. Two 25cm x 45 cm "Parcel Net"s from your local automotive store (I got mine from Ebay)
2. Some industrial strength self adhesive Velcro strip (2cm wide) - the soft side for my nets but ........
3. Four small penny (fender) type washers from your garage odds n sods box.
You'll need to be able to bend and trim the metal rod that reinforces the net but I'll leave that to your imagination.
The penny washers shown here are used with the original screws to just grip the net (see second picture). As I don't intend holding back significant weight this is good enough.
At the front of the pannier, top of the net, I pierced the velcro on the net and used the screw situated in the pannier (next to the retaining cord roll) to hold that in place.
The last couple of centimetres of net above that are held with another bit of velcro. I couldn't get a decent picture of that though.
General View (Note the screw just to the left of the retaining cord box)
Penny Washer grips the net at the bottom
The small plastic box you see holds my spare bulb set (European requirement) and I'll keep a spare set of gloves in there too. In my other (Left) case is my puncture repair kit.
I used to stow all this gear under the seat of my FJR1300 so I'm pretty chuffed to find a place to keep it all since BMW take all the undersea space for themselves!
France here I come
