I just bought my fourth BMW. It's my first pre-servo ABS bike. It's a '96 R1100R with about 57k miles on it. It is in almost perfect condition. When I was backing it out of my garage the other day, there was a type of grinding sound. I thought that it may be the gear-drive for the speedometer but upon closer inspection, I found that the rotors are very loose and the grinding is ever-so-slight binding between the rotors and brake pads. There is a lot of left to right play in both rotors. Braking is fine. ABS is fine. I'm sure that this topic has been discussed in great detail before but since I am new to the site, I haven't viewed any.
Is it normal for the rotors to have a lot of play? My R1150R, K1200RS and R1200GS do not have problems like this. I have never had a Japanese bike do this. Should I worry? Is it worth replacing?
Floating Brake Disc
Re: Floating Brake Disc
Hello Adam,
the R1100R does have so-called floating discs hence it is normal that the discs have horizontal play. Nothing to worry about.
Brgds
Oliver
Brgds
Oliver
Hi Adam.
Yeah, when I first got my R850R (1998 model, same brakes as your bike) I was surprised at the amount of "floating" that the floating discs did do.
AFAIK, they are supposed to be that way, certainly I have had no trouble with regard to brakes in the last 35,000 kilometres.
You're later motorbikes have semi-floating discs, because folk didn't like the occasional odd noise from fully floating discs when wheeling the bike around at low speed.
Relax and enjoy the bike.
regards,CrazyCam
regards,CrazyCam
- AdamWebber
Thanks for the replies. I won't worry about the discs anymore.
Objections your honor! The later 1150 models did NOT have have floating or semi-floating discs. Instead they have discs which are fixed to the wheels. I can judge because I have a R1150R front wheel in my R1100R. There is nothing floating or semi-floating.CRazyCam wrote:Hi Adam.
regards,CrazyCam
Brgds
Oliver
Fair enough, Oliver.
I don't have more modern BMW wheels close handy for examination.
I know that my Triumph has what they call semi-floating discs..... they look like they should "float" as in move about side to side, but they don't actually move.
There is a set of replacement "thimbles" to change the discs to full floating, which (I believe) racers use.
regards,CrazyCam
regards,CrazyCam
