What does the 12,000 mile service include?
Does anyone know what the manufacturer recommended 12,000 mile service list includes? 2009 R12R, ABS, ESA.
"Doogie"
2009 R1200R
Austin Texas
2009 R1200R
Austin Texas
- websterize
Re: What does the 12,000 mile service include?
I recently had the 12K done on my bike. Here's a compressed zip of the maintenance schedule PDFs.
Just had mine done last week to the tune of $600.
Blue 10' R1200R
Triumph Sprint ST (traded for)
gibbo111
I think the final drive change is every 12000m/20000km now not just the initial change
tinytrains
That sounds pretty steep for a 12K service. It is just a 6K with an air filter and final drive change, and my 6K was $216.bmwk100 wrote:Just had mine done last week to the tune of $600.
Scott
Scott Schifer, Torrance CA.
1988 K75 Low Seat
2009 R1200R
1988 K75 Low Seat
2009 R1200R
They did the coolant, brake fluids, valve check etc. 4 hours labor + parts. I thought that was a little steep. Maybe other can chime in to see what they paid at their dealer. (I don't want to hear from do it yourself'ers, because that's not how I choose to spend my time.) My 6K was about the same as yours.tinytrains wrote:That sounds pretty steep for a 12K service. It is just a 6K with an air filter and final drive change, and my 6K was $216.bmwk100 wrote:Just had mine done last week to the tune of $600.
Scott
Blue 10' R1200R
Here is a scan of the maintenance schedule page in the Haynes Service and Repair Manual for R1200 Twins '04 to'09. If anyone can recommend a better way for me to post this, let me know. You an message me if you want an email with a better copy.
John K
2008 R1200R
2013 HP4
2008 R1200R
2013 HP4
gibbo111
Coolant??? its only engine oil
I thought the brake fluid flush was every two years?
I was mistaken- 4 hours service- synthetic oil, brake fluid, spark plugs, air filter, mineral oil.-gibbo111 wrote:Coolant??? its only engine oil
Blue 10' R1200R
The dealer got me for spark plugs at 12k too, but I protested that they changed them without my authorization and BMW spec says to renew them @ 24k, They refunded the cost witch was nearly $100. I just crossed the 36k mark myself and did the bulk of the work on my own(engine oil w/filter, trans lube,final drive lube,air filter and alternator belt) I had the dealer adjust the valves , sync the throttle bodies and flush the rear brake juice(they did the front brake line recall too), the bill from the dealer was $100. The odds of a modern day spark plug being worn out at 12k is next to nil.bmwk100 wrote:I was mistaken- 4 hours service- synthetic oil, brake fluid, spark plugs, air filter, mineral oil.-
ASK WHY
What was the mineral oil for? The clutch fluid is not on any list to be changed - ever. And since it isn't hydgroscopic, it should never need changing unless you have a leak. And plugs aren't due at 12k, and I don't believe the air filter is, but I could be wrong on that. Brake fluid is every 2 years from the DATE the bike was MANUFACTURERED. The should have included rear drive oil.. that's a 12k service item now. IMHO - unnecessary, but I do mine anyway. The first time I did it was at 36,000 miles when they came out with the new recommendation. The oil that came out looked identical (clarity, lack of goobers) to the oil I put in. Ditto when I did it again at 48,000 miles. I think I may wait to 72,000 to do it again.bmwk100 wrote:I was mistaken- 4 hours service- synthetic oil, brake fluid, spark plugs, air filter, mineral oil.-gibbo111 wrote:Coolant??? its only engine oil
Ugh, sounds like I paid for a lot of things I did not need. I will address this with my dealer next time I go in. Air filter definitely was on the 12K service list.
Blue 10' R1200R
