New topic? R1100RT-P
vicco27
Post by vicco27 »
I still would like to have a correct wet weight for the bike. I posted yesterday about my impending acquisition R1100RT-P.
ICBMguy answered the questions about model designation and wire spoke wheels.
Thanks, vicco27
Paladin -- Have Trike Will Travel
bimmerguy
Re: New topic? R1100RT-P
Post by bimmerguy »
General information
Model: BMW R 1100 RT
Year: 2000
I converted my RTP to 2 seater and radio box and crash bars only added 20lbs to bike. It handles so well, you would this it's a 600cc sportbike. I rode sportbikes before this and my RTP will lean father than I have guts to go.
Displacement: 1085.00 ccm (66.21 cubic inches)
Engine type: Two cylinder boxer, four-stroke
Power: 90.00 HP (65.7 kW)) @ 7250 RPM
Torque: 95.00 Nm (9.7 kgf-m or 70.1 ft.lbs) @ 5500 RPM
Gearbox: 5-speed
Chassis, suspension, brakes and wheels
Front brakes: Dual disc
Rear brakes: Single disc
Physical measures and capacities
Dry weight: 256.0 kg (564.4 pounds)
Power/weight ratio: 0.3516 HP/kg
Seat height: 780 mm (30.7 inches) If adjustable, lowest setting.
Alternate seat height: 820 mm (32.3 inches) If adjustable, highest setting.
ICBMguy
Post by ICBMguy »
Found this on another forum. It's the brochure for the R1150RTP so the weight may be slightly off, but at least it'll get you in the ball-park!
http://bmw.brownmotorworks.net/brochure ... ochure.pdf
2000 R1100R Graphite & Ice Blue "Jasper"
