2011 R1200R left side 'system case'.."heat shield"
ammolab
Post by ammolab »
Does the left BMW case have a heat shield? Is it on the
bottom of the case where you can see it? or inside the
case structure?
Red 2011 R1200R
Blue 1986 K75C
Steel Grey 2002 M Coupe
jkhomes
Donating Member #: 939
Re: 2011 R1200R left side 'system case'.."heat shield"
Post by jkhomes »
My 08 R1200R does not.
John K
2008 R1200R
2013 HP4
boxermoose
Post by boxermoose »
The owners maual for the 2011 shows a heat shield mounted on the outside - it also states that although the panniers from the older R-R's are compatable they recommend that you install the heat shield on them
TANSTAAFL
ammolab
Post by ammolab »
boxermoose wrote:The owners maual for the 2011 shows a heat shield mounted on the outside - it also states that although the panniers from the older R-R's are compatable they recommend that you install the heat shield on them
I thought so...I noticed the "right" case is the same part # for the old Rs and Sts....but the 2011 left case has a different part #.
My set of cases that my dealer ordered has the OLD part number and no heat shield.... but my dealer is not the sharpest tool in the shed.
Red 2011 R1200R
Blue 1986 K75C
tinytrains
Post by tinytrains »
My 2009 does not have a heat shield and things in the left bag do get warm. Don't leave a chocolate bar on the bottom of the bag.
Scott
Scott Schifer, Torrance CA.
1988 K75 Low Seat
2009 R1200R
BoxerSteve
Donating Member #: 879
Post by BoxerSteve »
When you talk about the "older R-R's" are you talking about R1150R's? Or pre-'11 R1200R's? If you mean R1150R's does that mean the bags from an R1150R would fit on an R1200R?
Jus wunderin'
ka5ysy
Triple Lifer
Post by ka5ysy »
Thats a "feature". It is used to heat the cappuccino while you ride.
MSF #127350 NAUI #36288
2011 RT
boxermoose
Jus wunderin'
I believe it's relative to the hexhead R1200R's
TANSTAAFL
Patch
Donating Member #: 975
Post by Patch »
It is almost completely invisible on the bike...
2011 R1200 R
Patch
Post by Patch »
Here is another shot... it's just off the plastic a bit enough to 'hopefully' move heat away to keep my candy bars safe!
Lately i think i need one for the top of the case - another high 90's day coming tomorrow :lol:
2011 R1200 R
