Opinions...?
I've got some good install tips and pics that I'll post later...
Yup, the stripes are too small. I bought the tape that Creamora used, but it's not the right size when next to the existing double stripe. I will get a matching size dual-stripe on there. I want it exactly the dimensions of the bottom tank stripes.mogu83 wrote:My read on the stripe (you asked), I assume it's tape. Tear off the lower stripe and replace it with a single 1/4 inch white stripe run parallel to the remaining small stripe. That will closer match the stripes on the tank. The two small stripes seem lost, if your going to go, then go BOLD.![]()
That's a good idea. I'll try to do that...zei220 wrote:Hello,
Great work, any chance you could scan s template in for people to copy?
Thanks,
dave
That's why RT's cost so much more than R's!celticus wrote:Dang fairings are costly.
I keep tweaking it! Right now, I've one in a temporary position to see if I like it. Looks good so far, then I have to take it off, make a final version and measure it.zei220 wrote:Any progress on the template?
