PDF of 2011 R1200R, Classic owner's manual
websterize
Donating Member #: 710
Post by websterize »
2011 owner's manual
I noticed different run-in RPM limits and a necessary heat shield for a System Case. I love manuals.
2wheels
Donating Member #: 547
Re: PDF of 2011 R1200R, Classic owner's manual
Post by 2wheels »
Yes, I wondered about heat shield - does new model run hotter or is the case closer? Never aware of a problem before.
Like the bit about keeping twisty hilly roads while running in!
Brian
Don C
Post by Don C »
The new parts fiche is online as well.
http://www.maxbmwmotorcycles.com/fiche/ ... d=03252011
creamora
Donating Member #: 964
Post by creamora »
Thanks Don.
Case Heat Shield, great... #-o Item #482 on the list.
I checked the bottom of my case and did not note anything out of sorts or discolored. I commute with the cases more often than not. Looks like a doable project to fabricate one. :-k
2009 R1200R Black
websterize
The retrofit kit heat shield for the left system case is part 77427729294 — no price listed at Max's or Chicago BMW.
