Rather than reply there, I started a new topic as I've been obsessing about the same thing. I really want a headlight similar to the dual one seen on the Lo Rider concept bike. You can see a picture at this link: http://www.webbikeworld.com/BMW-motorcy ... -lo-rider/celticus wrote:Oh Yeah me too.lewellen wrote: What I'd *really* like to see for the R1200R is a dual headlight setup. I think that would look great on the bike.
- Lewellen
One option is a headlight built by an Italian company called Ghezzi-Brian. Ghezzi-Brian builds modification kits for Moto Guzzis. One of their bikes is called the Furia and it has a streetfighter style dual headlight which they also sell separately. You can see both on the first page of the pdf you will find here: http://www.ghezzi-brian.com/documents/TuningCat_EN.pdf. The Ghezzi-Brian light plus the fairing is 630 euro for the MG V11. They indicate that they sell the parts for other bikes as well. The prices are 307 euro for the light and 223 euro for the fairing.
The problem with all of the above is that they are mounted diretly to the tubes of upside down forks which are static in the area where a headlight is mounted. A typical fork mounted headlight isn't an option for an R1200R because the first time you hit a bump the top of the fork will compress and destroy whatever is mounted to the inner tube of the fork. Any headlight must either be mounted to the existing mounting points on the R1200R at the very top of the fork clear of the path of the outer fork tube or mounted solely to the outer fork tube.
I wouldn't want to move the headlight because of the odd shape of the leading edge of the gas tank of an R1200R. It has that huge divot taken out of the front that allows the fork and paralever to be recessed into the tank. Without a headlight to cover that chasm it will look a bit like a face without a nose.
Finding the actual lights for something similar to the pictures above is actually really easy. Visit Hella at http://www.myhellalights.com/index.php/ ... gen-lamps/ and go to the bottom of the page where they have 90mm and 50mm halogen headlight modules including low beam, high beam and dual. The halogens run $50 to $150 per module.
For literally 10 times the price, they also have xenon which you can see here http://www.myhellalights.com/index.php/ ... on-module/ and here http://www.myhellalights.com/index.php/ ... -bi-xenon/.
The real challenge in making this conversion is getting the bracket made. At some point I'm going to find a machine shop to do it for me.
Another dual headlight option if you want a different look is the AC Schnitzer kit that takes the dual headlight off an F800 and fits it to an R1200R along with a custom windscreen for a mere $1200 plus paint.
So what else is out there that I've missed? Is anyone aware of anything? I've seen the LSL streetfighter kit. It would work but it mounts to the forks so an alternate bracket would be needed and the shape makes me think it was taken out of a superbike fairing. There are some black and chrome 4 inch dual headlights mounted side-by-side but I really don't like them and Acerbis makes some fairings with integrated dual headlights that cost around $89 and look it.
