crackling noise
dwheels
crackling noise
Post by dwheels »
I have a 2004 r1150rt and it has started making a crackling or frying bacon noise when cranking it open around 4000rpm. Can anybody tell me what that may be?
thanks
dwheels
Re: crackling noise
Post by dwheels »
I forgot another question, is there any other backrest besides "Backup" for my RT?
chibbert
Donating Member #: 202
Re: crackling noise
Post by chibbert »
I don't know about the backrests but I am wondering about your noise when cracking it open. Do you think you could possibly be hearing pre-ignition? Regular grade gasoline is mor elikely to do this than premium (I don't know which you are using) but pre-ignition can sound like a bunch of little teensy tiny explosions - perhaps that is the frying bacon sound you are getting. If you're running premium already - try getting it from somewhere else and see if the problem persists. If it continues - maybe a motronic reset would help?
2004 R1150RS
twindave
Donating Member #: 724
Re: crackling noise
Post by twindave »
It may be what is referred to as "Pinging." My scooter made a similar noise when I cracked on the gas. It didn't have that typical automotive "ping." It kind of sounded like scrambling metal (not sure if that's a good description, but It didn't sound good)...I thought it was serious.
At any rate, I dumped a lil seafoam in the tank, per instructions, and some high test fuel. It cleared up the noise. Anytime that noise returns, I repeat the remedy....usually once per Summer. :D
Hope that solves the issue for you.
Know it, Love it, Ride it
macx
Re: crackling noise
Post by macx »
The warmer the air temp, the more likely you are to experience pre-ignition.
Unless it's pretty cool out, I add an ounce of 104 Octane boost per tankful and always use
91 (can't get 93 around here) irregardless.
chibbert
Re: crackling noise
Post by chibbert »
It is my understanding that octane (more or less) does not lead to pre0ignition or pinging. Supposedly there are additives in premium gas which inhibit pre-ignition. I somehow think it makes the fuel slightly less volatile.
2004 R1150RS
dwheels
Re: crackling noise
Post by dwheels »
thanks everybody for the input
I always put 89 in tank but will monitor where I get gas
