allanj255,
To clear up the apparent confusion,
Columbia03BMW said he
"I worked up a very crude picture using paint on my computer to at least give me some idea of what it may look like". I believe that is Windows crude but menu available "Paint" program.
CycleRob actually painted his using an 11oz rattle spray can of (On the label)
"Plasti-Kote fast dry Engine Enamel, Resists heat to 500DegF" (On the cap)
"Universal Black No. 203". Any brand engine enamel will be as good or better, as they are designed for the heat and oil resistance after curing. The covers were wire brushed and sanded smooth for paint adherence, cleaned with contact cleaner then painted with 3 light coats of paint, drying in the sun in between and for the final. The finish is semi gloss, but, like all painted surfaces, is no match for the durability of (baked on) powder coating.
For durability,
NOTHING beats powder coating as a color finish! It is so durable, you must be careful that the person/company that applies the oven cured finish takes the correct precautions as to where it is applied. Specifically: Bearing race areas=
Absolutely NONE!!! Valve stem holes and the bead seating OD of the rim = Absolute
Minimal. Any carelessness or lack of communication will result in a lot of time wasted spent trying to remove the very durable epoxy-like coating without damaging the critical dimensions of the Aluminum parts. BTDT with customers that brought in their spiffy new powder coated wheels for bearing and tire re-installations.
bikermeow, Powder coating the engine and trans would require total complete disassembly so the individual parts can go in an oven after the electrostatic paint application.
Dr. Strangelove, No . . . . did not document the valve cover color job.
Durability is like paint, so the usual care is required. On the plus side, re-do's are just sandpaper, a spray can and quality time in full sunlite. I liked the black cover's look better than bare.
Hope that cleared things up.
