LED HP turn signals
venturi
LED HP turn signals
Post by venturi »
I'm really not fond of the large turn signals and the big orange lenses. the led hp2 lights really disappear (when not in use ;) ) The LED turn signals really clean up the look of the k1300s. Look at the following images and see how unobtrusive the leds really are.
I even use them on my r1200r, and if you look at the last two pics, you will have to focus to really see the turn signals :)
K1300R HP 2d D, HP QS HP LED TS HP Wls HP CF LR Pan ABS
R1200R ABS Comp CS H Grps LR TrngWShld
websterize
Donating Member #: 710
Re: LED HP turn signals
Post by websterize »
I installed the LEDs last weekend and like them. First heard about them from Dauntless's post, with photos:
viewtopic.php?f=20&t=16889
mogu83
Post by mogu83 »
Venturi,
Your just the guy I was looking for, a R1200R and a K1300S. You most likely realize the tail lights are interchangeable (at least physically). My question is are the plugs that connect to it the same. Take a look if you have the time. If they are it will surely cause a run on K1300S taillights.
Thanks Harry
venturi
Post by venturi »
I already looked at it... sigh, they are not the same. I would have jumped on it if they were
HOWEVER
I do have the Gizmomil LED lightbulb in there instead of the stock and it has dual intensity, and lends a digital look but uses same lens housing and no LAMPF code!
to see the trial and tribulations please go to my other thread:
http://www.i-bmw.com/showthread.php?t=21368
V
mogu83 wrote:Venturi,
Thanks Harry
