OMG... $43 F....ing dollars for a tool that pulls the spark plug connector off????? Is everyone taking crazy pills or WHAT!!! I know I'm a Scottish cheap FAT BASTARD... but CRIMANITLY!!
it's ok....... it's ok........... I'm alright now.... (deep breaths....... deep breaths....)
The guy at the dealer says you can't get the little plastic ones any more.... ok... FINE!
He did say that I MUST disconnect the cable from the coil first..... True????
My Clymer manual isn't here yet so.. as far as I can tell... the connection is buried up under the tank.
So... I ordered the 12" feeler guages from the Snap-on guy... thru my fav auto parts guy.... and will follow instructions for the Oilhead for dummies section and do the valves... The gauges won't be here till next Wednesday..... waaaay too long to not ride (I'll go nuts)...
BUT... on my ride tonite, it seems that the ticking noise is getting worse on the left side.. Is this possibly from Rocker Arm play????? or is it really Cam Chain Tensioner...? Should I just not ride until I get in there?....
I remember one of the posts for valve adjustment that linked somewhere??? talked about taking up the slack for the rocker arm prior to valve adjustment. Am I correct????
I was going to order a valve cover for the right side (the bike went down w/ previous owner.. and it's got a small crack... leaks a tiny bit of oil on each ride... maybe a tablespoon (big T) on each four/six hour ride... ) and also get the cam chain tensioner upgrade at the same time.... unfortunately.. I just started hearing a squeal from the clutch.... (funny sound thread) and will wait for the Clymer manual before checking out the clutch slave (Thanks CycleRob... will keep you posted)
So... I'm in holding pattern... but this ticking is getting worse.... and driving me crazy...
btw... I'm up to 8500 miles on the odometer... cuz I know someone will ask
