replacement grips
toddprosky
replacement grips
Has anyone replaced the grips on an R with heated grips (2004), if so where did you get them and which ones out there look good and work well with heat?
The best way to solve a problem is to destroy its source
Re: replacement grips
I'm currently waiting on an order placed from Chicago BMW over two weeks ago to replace my grips. Thanks for reminding me - I'm calling them tomorrow to see where my parts are.toddprosky wrote:Has anyone replaced the grips on an R with heated grips (2004), if so where did you get them and which ones out there look good and work well with heat?
Once I do get the parts, I'll try to document the process nad post part numbers I used. Hopefully I'll replace only the grip, while retaining the heating element for low cost.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
