Hi
I think I just figured out that leaving the heated grips "on" when parking the bike for a few days can drain the battery. Am I correct ? It refused to start twice recently and I had to put the battery on charge both times. Do you think that I damaged the battery ?
Heated grips left on = battery drainage ?
ridgerunner
DJ Downunder
Rog(UK) - Yorkshire Dales
DJ is correct, you fail to mention how old the baterry is. Most of the time the battery life is put to a test in cold climates....since starting the bike cold with the oil the consistency of Aunt Jamima pacake syrup places a tremendous load on the battery. If the battery is weak to begin it will continue to deterirate unless it is fully recharged.
I think that Qubec is "colder than a witches txx".....correct?
ridgerunner
Thanks guys
Thank you for your help.
Re: Heated grips left on = battery drainage ?
I'd bet that you might of turned your key one click to far counterclockwise.ridgerunner wrote:Hi
That would put your bike into "Park" WTF ever that is for I don't know. Alls I know is that that is what I've done B4. Only to wake to a dead battery
