Rain Repellent
- Max Continuous
Rain Repellent
Does anybody here use a rain repellent such as RAIN X on their helmet visor? I was contemplating making a small squeegy for my glove but was wondering about repellent. Would appreciate any comments, observations, experiences or suggestions.
I use it & it's extremely effective. Even when stationary, the visor is so slick that gravity is sufficient to pull the droplets right down. The one thing that I've noticed is that very fine droplets can accumulate, such as when following a large truck - the fix is to simply look left or right and let the wind wipe your visor clean.
m
m
- priapismic
I've used Rain-X a lot in the past, and it's always worked well for me. Some people will warn you away from it, saying that it will promote swirling and scratching on your faceshield, but I've never had a problem with that. Today's modern shields are pretty hard and usually made from Lexan. Use a very soft cloth to apply it; I use an old cloth diaper, which is also my preferred cleaning cloth for windshields and faceshields.
I use liquid glass on everything. My visor still looks brand new after 3 years. That being said, I don't see why you couldn't use wax on it instead. Rain-X is a pain to put on and very expensive and wax would work better anyway.
Not only that Liquid Glass(or any wax) makes the surface slippery so bugs and crap are less likely to stick to it, and when they do, much easier to remove.
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
2004 Honda CBR600RR
1996 Ducati 900SS
+1priapismic wrote:I've used Rain-X a lot in the past, and it's always worked well for me. Some people will warn you away from it, saying that it will promote swirling and scratching on your faceshield, but I've never had a problem with that. Today's modern shields are pretty hard and usually made from Lexan.
I've been using it for over 100,000 miles on various helmets and NEVER had any problems with it. The stuff works great!
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
- Dr. Strangelove
- Max Continuous
Rain-X works OK for a while on my plastic visor. Never had problems with damage.
If the mucky road spray lasts for more than an hour or so the effectiveness seems to lessen.
A BMW dealer recommended natural Pledge ,and nothing else, on a polycarbonate windscreen. So maybe worthwhile trying on visor.
- mcooperstein
- Moderator
fog repellant too..
One of our charter members Gene Menzies started making and selling "Fogtech" which mitigates the effect of fog on your shield. It works pretty darn well although it doesnt last forever and will require reapplication after every so often.
member #3
member #3
- iowabeakster
