GVWR
scootaman
GVWR
Post by scootaman »
G'day from Downunder.
How much strength/leeway is in GVWR on the 1200R
Ive been informed I need a K1200GT for 490 payload but want to know if that will kill the 1200R.
As an old R rider I like the twins.
Would an aftermarket shock help, is subframe strong?
Be kind now, some of us cant help it.
DRothermel
Post by DRothermel »
Howdy mate:
From the BMW site:
Weight - Dry
437 lbs.
Max permissible weight
923 lbs.
The math says 486 payload. Somewhere else I read 500 lbs even. I'll check my owners manual and if it should say something different I'll post again. The new 12R deserves a test ride by you. My guess is, ride it, you'll buy it.
I checked my owner's manual. That's where I had seen the 500 lb payload figure. It says, wet weight with 90% of the tank full is 492 lbs. Permissible gross weight, 992 lbs. 500 lb. max payload.
Richard
BMWMOA, IBA Member
200,000 Mile BMWMOA member
2007 RT. TPM, ESA, ASC
scootaman
Thanks DR
Post by scootaman »
Its almost do able. No panniers etc.
There must be (hopefully) a safety/conservative factor built in.
Cheers
Scootaman
