Almost there : Garmin 2720 + wired helmet speakers ...but
John I. Stephen
Post by John I. Stephen »
Well the "but" is because I am only hearing the rh speaker from my Garmin 2720. The Garmin female audio plug requires a 2.5mm male (stereo) jack. No problem - my helmet speakers came with an adapter for the standard 3.5mm jacks (and I had already bought an adapter in any case).
HOWEVER, if I slowly remove the jack, there is a point where I get both right and left speakers working. However it's a poor connection; clicked-in (as it should be) and it's only my right ear which receives the dulcet tones of Emily (UK English) Sat Nav (my wife says we have a relationship !!).
So how can I solve this one; it's NOT a problem with the helmet speakers because, if I plug in a standard iPod on the standard 3.5mm jack; it powers out of both speakers.
Any ideas ??
2002 R1150R Blue with ABS
iowabeakster
Post by iowabeakster »
the adapter is "stereo", correct? two plastic rings on the male protuberance.
is the output from the garmin in stereo? seems like it would be a waste of design time to make a stereo gps. i bet that the output is mono.
i would guess that you might need to locate a different adapter that has mono input and a splitter (2 channels of mono) output. i bet garmin sells what you may need.
crashfaster
Post by crashfaster »
I agree with iowabeakster. Sounds like it's a mono issue.
Arbreacames
Post by Arbreacames »
I had similar problems with a cell phone. I found that some 2.5 mm plugs are meant for mono + mic, and others for stereo. The adapter I bought did not work and I had to go to the phone provider to get the right headphones.
Carlos D.
John I. Stephen
Thanks chaps, eBay's got a 2.5mm Mono Jack Plug To 3.5mm Stereo Socket Adapter for the sum of £1.24p !!
Thanks again !
John I. Stephen
Sorted !
The 2.5mm mono to 3.5mm stereo adapter plug arrived yesterday and works perfectly; I now have my SatNav's voice central in my Arai helmet :)
Just have to wait for the snow and ice to clear and I'll be able to use it properly!
