Gas Stains on Transmission
phastphil
Post by phastphil »
Can't find anything by SEARCHING, so I'm posting a new topic for some feedback.
I had a GAS leak on my R1150RA, which resulted in yellow/brown stains on the transmission case. Pretty ugly. The 'dealer' says nothing will take it off, and I've tried any number of cleaners etc. He said lightly mist it with a close color of paint, but somehow I'm not happy with that remedy.
The question: How do you remove the stains short of repainting the case?
BTW: the gas leak was covered under the RECALL, so I'm a bit unhappy my pristine bike now has stains caused by a factory error. Anyone get BMW to do anything about the staining issue?
PhastPhil
2002 R1150RA, Black, Parabellum Super Tour, Kisan Signal Minder, System Cases.
iowabeakster
Post by iowabeakster »
your stains are not uncommon. i cant recall anybody that found a way to remove them.
your best bet is to approach the dealership with a warranty claim.
if your dealer is worth their weight in spit, they will insist that BMW cover the cost of replacement under warranty. how well they lobby on your behalf may determine whether you should continue to do business with them.
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
Hey PhastPhil, thanks for the post and sorry to hear about the stains on your bike. I'm also sorry that I haven't heard of anyone being able to remove them. If you find a way, be sure to let us all know!
Boxer
Donating Member #: 2
Post by Boxer »
There was a simple fix for this a while back but in Ronald Reagan's infamous words, I just can't remember what it was.
It was something like Windex or...I dunno...maybe the person who discovered it will pipe in here.
NHighCotton
Post by NHighCotton »
Boxer wrote:There was a simple fix for this a while back but in Ronald Reagan's infamous words, I just can't remember what it was.
Oven cleaner???
Not sure, I think that was for the exhaust pipes :idea: ....Reagan moments are hell.
2003 R1150R (SOLD 8/07)
(9/07) 05 FJR1300
1986 R80RT
1974 R90s antique (on the road again)
single650
Post by single650 »
Do NOT use oven cleaner on aluminium alloys, you'll ruin them.
'03 R1150R Rockster
'94 K75s
gel9001
Reagan
Post by gel9001 »
I don't think its cool to make fun of Alzheimers. I'm 41 and find myself forgetting sh*t, its scaring the f**k out of me.
Why are more people coming down with Alzheimers these days?
Gene
Dauntless
Post by Dauntless »
I was able to remove my stains with Dawn dishwashing soap. I discovered my leak fairly early so the stain never set for more than a week. I just put it on full strength and scrubbed it off with a rag and used a tooth brush in the hard to reach spots. Maybe that Dawn foam will work on tougher stains. YMMV.
Boxer
Post by Boxer »
Ooo! Now I remember! It was Dawn dishwashing detergent! :?
phastphil
Post by phastphil »
Dauntless and Boxer:
Thanks for the tip - I'll give DAWN a shot - can't hurt. Unfortunately my stain has been there for a few months. Seems rather strange that you build such a great bike and use a paint that is easily damaged by of all things - GAS. Wow who would of thought you would have gas around a gas fueled bike and OH is that the gas tank right above it? Stupid, Stupid Stupid. Oh did I say it was Stupid. :smt021
Phil
PhastPhil
munchmeister
Re: Reagan
Post by munchmeister »
gel9001 wrote:I don't think its cool to make fun of Alzheimers. I'm 41 and find myself forgetting sh*t, its scaring the f**k out of me.
Gene
:shock:
munchmeister
'02 R1150GS
'01 F650GS
'04 R1150R - R.I.P. 4/29/07
TicTac50
Donating Member #: 586
Post by TicTac50 »
I used Easy Off. :shock: :shock: :shock:
Spray and let it sit for 1 min.
Stain is gone and I don't see any damage to the paint :D :D :D
phastphil
Post by phastphil »
Tic Tac 50
Thanks, I'll try that after the DAWN. DAWN would appear to be less volatile - Easy Off might work OK - just concerned about the interaction with the aluminum?
Phil
PhastPhil
NHighCotton
might also try gas or kerosene,
makes sense that new gas might loosen old gas then go back over it with DAWN.
scrub and a wash, scrub and wash....makes for a good thread on what tools are used to clean those hard to get to spots???? :wink: hint.
(9/07) 05 FJR1300
1986 R80RT
phastphil
Post by phastphil »
BTW: Just talked with the Easy Off folks - they don't recommend the oven cleaner on aluminum - which I assume the transmission case is made of?
So far the DAWN sounds like the most non-volatile solution.
Phil
PhastPhil
phastphil
Post by phastphil »
OK, so we are talking about stains - I stained my driveway using a Silicone based Tire Dressing. I just had it pressure washed - no help. Looks as bad as it was. Just back from Home Depot - bought some Concrete Cleaner - will see if that helps, but wondering if there were any other suggestions?
PhastPhil
redr1150r
Gas Stains
Post by redr1150r »
Had the same problem with a gas leak on my beakster. Went to my local dealer (HAP"S in Sarasota). They contacted BMW and were told to replace my gear box under warrenty. BMW picked up the tab with no charge to me.
redr1150r #381
"Good judgment, comes from experience, experience comes from bad judgment"
phastphil
Post by phastphil »
redr1150r
Wondering when did you have that done? Was your bike one of the recalled for the gas leak as well?
PhastPhil
zooomart
Stains
Post by zooomart »
Try some goo-gone. I have had good luck with it on the road grime and seems to not harm paint. I wouldn't be thrilled in having to break in a new gearbox, hope you get the stains out.
DK
Post by DK »
I went thru this same ordeal this past summer. I tried Goo Gone, Goof Off, Dawn, and every other cleaner. I thought I had gotten them out but a few days later I noticed them more.
I spoke to Kent Holt at Holt BMW in Athens, OH about it because he does a lot of painting. He said the UV in sunlight seems to cause the stains to get darker. He also said you have about 5-10 minutes to get the gas off before it stains. Bottom line is the only way to fix it is to repaint. He also said this has been a problem with clear coat and paint that BMW uses on the engine and he doesn't know why they use it :!:
Dwayne
'04 R1150R Black
