Fuel disconnect . . .
qfman
Exclusive club
Post by qfman »
Now you get to join the rest of us with yellow engines from fuel running down the sides...... Tried everything - couldn't clean it off.
Now I just call it character...
Tom
http://members.optusnet.com.au/~lonergans/
Arbreacames
Post by Arbreacames »
boxermania wrote:If your bike is a few years old and you have taken the tank off a few times, I would consider replacing the quick connects
If you had replied a bit faster, you could be claiming "I told you so." But your post comes one month too late. A day after my message, as I was completing my ABS bleed I tried to reconnect the fuel line couplers and, of course, one broke. I got the white McMasters. I also have a ton of spare Buna-N o-rings, so if anybody needs a few, send me PM and I can send you some.
Carlos D.
challey
Donating Member #: 365
Post by challey »
This may be silly question but, is there any difference between the QDs from Smallparts vs those from Omega other than the chrome plating? From what's been posted, it looks like folks don't really have a preference.
Replacing the stock QDs is my next weekend project - all the postings about the unexpected failures have me nervous.
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
yjleesvrr
Post by yjleesvrr »
cc wrote: If your QD's fail you can replace them with a short piece of steel, brass or copper tubing of the appropriate size.
Thanks cc. I'll probably do that in the interim. Do you have any recommendations as to what diameter tubing I should buy?
Member #93, June 2002
'14 BMW R1200RT "Wethead"
'77 BMW R100/7 "Airhead"
cc
Post by cc »
The fuel line is 8mm so I used some 5/16ths O.D. tubing. Copper is available at hardware stores, steel at your auto parts store.
_______________
Charlie
cc
Post by cc »
challey wrote:This may be silly question but, is there any difference between the QDs from Smallparts vs those from Omega other than the chrome plating?
The o-rings on the Small Parts units are internal to the female end and are therefore not easily replaceable as it appears to me. I think there may be photos over on Adventure Rider.
Of course for the price difference you could buy two extra female ends and swap them out every time you break the connection, thereby allowing the o-rings to recover. :lol:
_______________
Charlie
yjleesvrr
Post by yjleesvrr »
Charlie - thanks again for the info. I'll probably opt for the copper tube for now and go with the metal QDs in the spring.
popgazer
Post by popgazer »
Look in the plumbing dept. You should find 3", 1/4" OD straight braded connector ~$0.75. Worked perfectly for me.
marecycling
Viton VS. Buna-N
Post by marecycling »
Just a quick note about o-ring composition. If you ride in Massachusetts as I do, then your gasoline is 10% ethanol. You want a quick disconnect that is Buna-N as opposed to Viton, due to its superior resistance to deterioration from ethanol. The Omega disconnects are fitted with the Buna-N o-ring. I would also assume that since the o-ring fitted to the Omega disconnects is mounted to the male end of fitting that it would be much easier to replace if damaged.
The "good things" that come to those who wait, are just the "leftovers" from those who didn't!
yjleesvrr
Post by yjleesvrr »
Most metro areas seem to have shifted to gasohol. And they charge more for this crap. Most of Virginia carries real gasoline for $2.09 for regular. In Northern Virginia, most gas stations charge $2.19 for gasohol.
Gasohol doesn't last as long as regular gas. A friend of mine who runs a motorcycle shop says that regular gas stays stable twice as long.
