Missing inspection cover
I need advice and council real bad right now. I was washing down my 04 rockster, getting it all cleaned up and ready to pull the valve covers to do an adjustment (My first time, 12k miles), and as I was looking around for the inspection hole on the right side, the one that's supposed to be covered with a rubber cap...well...no rubber cap!!!, just an open hole. Honestly, i simply do not know how long it's been off, and I could not have missed getting water in there while I was washing things down....Last week also???!!! I've been reading in my Clymer manual for a half hour now and for the life of me I can't figure out if this hole leads directly to the crankcase and engine oil, or if it's a dry area where the clutch resides. Please someone tell me I'm not screwed here....Heeeeelp!!!!!!!!!!!
For I dance,and drink and sing, till some blind hand, shall brush my wing. Wm. Blake
Missing Plug
Here is the part # 11-11-1-744-327 for the missing plug.
+1 that!!!single650 wrote:Mine was missing. I got a new one and managed to pop it into the hole and out of site![]()
Now I just cover the hole with a bit ot tape.
I hereby propose an amendment to the Valve Adjustment for Dummies manual to include the directions of buy another cover prior to starting this procedure because virtually everyone drops that sucker in there at some point. Fortunately I was at Tom's (CTRider's) house learning the how to's of this job and were in close proximity to Cliff's BMW. Tom generously offered up his duct tape, got the new rubber cap and almost two months later THE dUCT TAPE IS STILL THERE!!! Been real anxious about it...
Craig
Life is too short to use cheap toilet paper
Member #457
95 R1100R Red
Member #457
95 R1100R Red
The OVAD already advises a trip to the dealer to buy a "Real Man's Plug".
Duct tape the hole.
You're doing your 12K. Change the oil and make note of any foaming. If the evidence of water in the oil isn't bad, don't sweat it.
Get a new plug.
I use the stock one. Comes off with a screwdriver, goes back on with my fingers. It's more oval than round, just like the hole. Orient it correctly, hold right side with pliers, reach behind throttle body and pop the left side in with middle finger of left hand. Pop right side in. Press hard in the middle to firmly seat it.
DSKYZD
Duct tape the hole.
Get a new plug.
DSKYZD
JOURNEY JUNKIE #187
This topic seems to come up frequently as it's pretty easy to loose the stock plug. I took the advice of the OVAD and got a he-man replacement plug and haven't had much of a problem. The part number is 11-11-1-744-327 and it only costs $1.
As Biff says, there are other ways of determining TDC, though I still pop the plug and use the flywheel since I'm used to it.
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
