Heated vest
Guest
Re: Electrics
Post by Guest »
dragonmojo wrote:I plan to wear these for the coming weekend, before sending them off for repair (due to the intermediate voltage).
I meant to say intermittent voltage.
Guest
Heated vest
Post by Guest »
Nice comparison. Hope your stuff gets back to you ok and you will share your experience with us.
bmwdave52
Post by bmwdave52 »
I have the BMW Phase Change pants. I found them more comfortable for all day wear than my Patagonia expedition weight capiline pants. The capiline pants were very warm in the morning and evening and very hot during the middle of the day. The BMW Phase Change gear is very expensive. You have to decide if it's worth it to you.
I have the Gerbing jacket liner and gloves and socks. (Hey I'm from California--we don't do cold)
I had the jacket liner tear at the shoulder too. The fix is to buy the next size up. They seem to run a bit small. Gerbings replaced it for me.
Be warned though--once you start down the heated gear road there is no turning back. :smt023
greer
Post by greer »
For folks trying to decide on electrics: This cold-natured rider highly recommends a jacket liner with sleeves. Big, big improvement over a heated vest for me. My Gerbings jacket liner fits pretty close, but has room in the upper sleeve area. I wear a couple of rubberbands on each bicep to clamp the sleeves down on my arm; like turning up the heat 20 degrees. Sarah
mofo
These folks are great...
Post by mofo »
I've got the gerbing heated liner. Excellent! No complaints. They have an assortment of wiring kits available to make everything adaptable.
http://www.gerbing.com/index.html
