oil filter
oil filter
My Clymer repair book is calling for 97in lbs torque for the oil filter on my o4 r1150r. Can anyone tell me if this correct please. Thanks in adv.
Packrat
Oil Filter
I did mine to just shy of 8 FT-LB which is 97 in-lb. First time I ever torqued an oil filter. Seemed about right. The filter just did not seem to ever tighten and it was scary using a long wrench to do this low of a torque (the only one I had that goes this low, and it is the beam type. My normal wrench is a click type). Since a value is given, I decided to use it. I prefer to use a torque wrench on all fasteners if possible. No leaks and no appearent issues.
Thanks for the replies. Thats how i do my autos Jamming and it does work for me also but had the torque wrench and the book gave a number that sounded high so thought i'd ask. Your right Packrat seems like alot of wrench for a small job but with the light setting it worked fine,with no leaks -Thanks again.
Re: oil filter
My Haynes said something like 11 nt/m, IIRC.AL wrote:My Clymer repair book is calling for 97in lbs torque for the oil filter on my o4 r1150r. Can anyone tell me if this correct please. Thanks in adv.
The bottom line is I torqued it to the correct value, whatever it is, when I did my first change last month, and noticed that the filter spun just about 1 full turn after the gasket contacted the engine case.
So, that's what I'm doing from now on...~1 full turn.
Not going to bother to check the torque....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
R1150RDave
Oil filter
Not many home DIY wil have a suitable torque wrench, turn it seat the seal then 1/4 turn is ample.
R1150R 2001 Red on Z6s in England. Done 30,000 miles.
