Has anyone any experience using Mobil1 Synthetic Gear Lubricant LS 75W-90 in their R1150R Transmission?
Thank you.
Mobil1 Synthetic Gear Lubricant LS 75W-90 Trans/R1150R
RadicalR1150R
Re: Mobil1 Synthetic Gear Lubricant LS 75W-90 Trans/R1150R
Yes. Using it in my Rockster, approx 30k miles, nothing bad to report, though I'd hoped for cold fusion.RadicalR1150R wrote:Has anyone any experience using Mobil1 Synthetic Gear Lubricant LS 75W-90 in their R1150R Transmission?
Thank you.
Seriously, spec is for GL-5 oil in this viscosity range, so it's hard to screw up. Until someone does thorough gear inspection on the tooth load zones and hypoid sliding surfaces, with comparison between contending lubricants, I'd just squirt GL-5 in there and ride. The inevitable commentary about this or that oil invoking smoother shifting or quieter operation is likely wishful thinkng.
Same experience here 50k and going strong.
R1200GS
2011 FLHTK
06 FLSTC
98 DR350SE
2011 FLHTK
06 FLSTC
98 DR350SE
Yeh ,you got me there. Wishful thinking indeed.
Today just changed my transmission oil . 75/90 semi synthetic Comma GL5. What a stink though from the stuff. Weird to see uncoloured lube.
The full synthetic stuff does not seem to be widely available in the UK.
