Hey folks!
I've been riding the 12R this week for the first time since the spring while my NineT is getting painted and am noticing a somewhat new and loud rattle at startup. Seems like it's coming from the right side cam chain, or is similar in sound to a loose cam chain coming from the right side. It does go away after a few seconds.
I remember Don posted a long time ago something about replacing the guides and maybe a tensioner and was wondering if anyone knows where the thread is or has more info on what I need to get to fix this.
A little over 100K miles on the 07' and I've not replaced anything inside the motor...
Thanks!
A Loud Rattle at Startup?
- Lost Rider
Re: A Loud Rattle at Startup?
N8
- '14 Dark White
- '14 R NineT
- '12 R1200R Classic
- '07 R1200R (Caged)
- '14 Dark White
- '14 R NineT
- Lost Rider
Awesome, thank you!
Now, how about the guides.... I guess I could search ADV for the GS... good thinking!
I did a pretty substantial search of the internets looking for a rail replacement on a Hexhead, but came up nada. I'm guessing BMWMOA is gonna be the only source for that, but I think you have to be a member on the site to access those articles.Lost Rider wrote:Awesome, thank you!
From most of the reading I've done, the tensioner replacement solves the rattle, but considering the mileage on your RR, there may be enough wear to justify replacing the whole kit. Best of luck.
N8
- '14 Dark White
- '14 R NineT
- '14 Dark White
- '14 R NineT
Joe - before changing any parts - try changing oil to Castrol TWS 10W-60 "Edge Professional" - made in Germany, spec'd for the HP2, and available at your friendly local BMW car dealership (ask for the "M3" oil..)
Cheaper than BMW-Motorrad's semi-synthetic, it's a full synthetic, type V based and is very good at quieting down noisy hexheads.
Hmmm, Edge oil; sounds like it's worth a try. I have a friend with an 07 RT that has a cam chain rattle. Now, if only there was a BMW auto dealer within 320 miles.
Kevin Huddy
Intrepid Incompetent
Canyon Creek, MT
Canyon Creek, MT
The last sentence above says it all. It very likely is a worn out camchain, worn camchain guide rail surfaces and worn camchain tensioner, ALL contributing to the new start-up clatter noise who's violent mechanical whiplash will now accelerate wear of all those components. As always, I would make the easy shots first. Try that heavier oil, then replace the camchain tensioner if that does not help.Lost Rider wrote: . . . noticing a somewhat new and loud rattle at startup. Seems like it's coming from the right side cam chain, or is similar in sound to a loose cam chain coming from the right side. It does go away after a few seconds. A little over 100K miles on the 07' and I've not replaced anything inside the motor...
Not sure about the next generation R1200 HexHead motor, but the past generation R1100/1150 OilHead requires the crankcases to be split in half to replace the camchain guide rails, a complete engine disa$$embly.
Quick check of HexHead Haynes manual 2.62....that is still the ca$e.
