Handle Bars and Steering Dampers
celticus
Donating Member #: 548
Post by celticus »
Has anyone put different handle bars on their R1200Rs?
Maybe something slightly wider is what I have in mind. Maybe some GS bars maybe Renthal of other aftermarket superbike bars.
Also what about after market steering dampers?
What is happening to my skin?
Air can hurt you too
dbrick
Donating Member #: 902
Re: Handle Bars
Post by dbrick »
David Brick
Santa Cruz CA
MrPMS
Re: Handle Bars and Steering Dampers
Post by MrPMS »
Wunderlich has some bars that might be what you're looking for.
danstl
Post by danstl »
Wunderlich's Touring Wellness bars are great. Have had them on 3 RR's and currently have them on my 07. They don't require risers, but move the hands up and back just enough for me to be comfortable all day long. They do require a slightly longer brake line, but that was a minor issue.
gibbo111
Post by gibbo111 »
i have a Hyperpro steering damper on my bike and am happy with the way it performs. It has adjustment and I used the progressive damper, here in Australia it cost me the same as the OEM part. Gibbo
celticus
Post by celticus »
gibbo111 wrote:i have a Hyperpro steering damper on my bike and am happy with the way it performs. It has adjustment and I used the progressive damper, here in Australia it cost me the same as the OEM part. Gibbo
Is there any difference you can tell between this and the OEM Damper?
gibbo111
Post by gibbo111 »
My original damper was broken in a off before I got my bike so I cant say, but I wanted a damper for it and as the cost was similar i went for the hyperpro. The mounting bracket isnt the most attractive part but it works ok. I am using it at just under the middle of the adjustment and the bike feels more stable at speed. If I still had the OEM on I wouldnt have changed it. Gibbo
