What seat are you using on your R1200R
What seat are you using on your R1200R?
Stock R1200R seat
38
30%
BMW Comfort seat
32
26%
Stock R1200R with AIRHAWK
7
6%
Corbin
11
9%
Sargent
13
10%
Rich's Custom
3
2%
Rick Mayer
10
8%
Wunderlich Active Comfort Seat
0
No votes
Other -Please specify in a posting
11
9%
Total votes: 125
Jedi5150
Re: What seat are you using on your R1200R
Post by Jedi5150 »
As of two days ago I'm now back on the list of Corbin riders. I just rode in and got mine made and love it (as I've loved the Corbins on my other bikes). One thing to point out, I happen to have the only Corbin seat in existence that will fit the 2011 model R1200R. If you mail order one it won't work, you have to have them custom make the entire seat for it to fit. There are enough changes in the luggage rack/ grab rail handles between 2010 and 2011 that the earlier seat won't work.
clooloss
Post by clooloss »
Stock seat with an Alaska butt-pad. Not exactly a 'magic carpet' but I can get an extra 100 miles or so between rest stops.
-c.
dbrick
Donating Member #: 902
Post by dbrick »
We're in Centralia WA, on our way south from Rich's, where Rad (R1100S) and I went for new seats. Here's the R12R outside the motel:
Way way better than stock.
Doesn't seem to be any way to change my vote from "stock" (when I first responded) to "Rich's."
David Brick
Santa Cruz CA
kidtwist
Post by kidtwist »
Rick Mayer seat. I just got it a couple weeks ago. So far so good.
ContraMoto
Post by ContraMoto »
Did you ride in to Rick Mayer or order it "untested"...?
'07 R12R Black w/stripes
North Cali
kidtwist
Post by kidtwist »
ContraMoto wrote:Did you ride in to Rick Mayer or order it "untested"...?
I ordered it untested. I'd never even seen one in person. I figured it couldn't be any worse than the stock seat.
nylife
Donating Member #: 956
Post by nylife »
Has anyone tried this place yet
http://greatdaytoride.com/Home_Page.php
here is a good review about the guy
http://www.ridermagazine.com/output.cfm?id=1694017
a friend of mine got his Aprilla seat redone and likes it, plus for the money its tough to wrong compare to everything else
2009 R12R
Stefan
Post by Stefan »
BMW Comfort seat (800mm seat height): Compared to the stock saet, this seat is just perfect (for me). Also during long trips (whole days/weeks), there is nothing to complain about.
Northernbiker
Post by Northernbiker »
Mine came with the standard height stock seat, and unfortunatley for me it was a real butt buster. After one season of riding I ordered a Sargent seat. It solved the problem of the seat being uncomfortable, but the cover on it causes me to keep sliding forward. Recently went to Demo Days and took out a R1200R with standard height comfort seat and it was much better - no problem with sliding forward. Now I'm going to have to go to the expense of replacing the seat again, just have not decided what to go with.
Chris
2008 R1200R Crystal Gray Metallic
'Ride it like you stole it!'
rokinrider
Post by rokinrider »
I'm using a sheep skin over the stock seat right now!!! I plan on having a local guy put a gel insert with 1/4" of foam over it for an air gap between me and the gel. If that does not work I'm going for a Sargent or Corbin!!!! #-o
Speed cures all handling problems.
2009 R-12R awesome
2000 HD FLHT 95" slightly modified
daveyator
Post by daveyator »
After 4 seats including the stock I wound up with BMW high comfort seat.
I finally got got an RT!
ContraMoto
Just two data points...struck me as odd...
The standard height* ("low") comfort seat measures exactly 800mm off the ground with the bike not loaded. Measured to a point about 8" (horizontal distance) from the front edge.
The regular "high" seat measures 860mm at the same point, not the 835mm stated in the parts fiche.
Even though the regular high seat compresses a little, it still sits 50mm higher than the comfort seat. It's a huge difference. I want something in between the two...
*There appear to be two "comfort seat" heights (low/800 and high/830) and three regular seat heights (low/770, normal/800 and high/835). Some parts fiches also show an "extra low".
North Cali
r12gecko
Post by r12gecko »
Corbin...
"Gentlemen, you can't fight in here - this is the war room!"
BigEasy
Post by BigEasy »
nylife wrote:Has anyone tried this place yet
Give him a call, the guys on the Z1000 forum swear by him. However, when I called him a couple of years ago he would not work on R1200R seats due to fracturing of the seat pan when stapling the cover back on. That may have changed.
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
eddiepat62
Post by eddiepat62 »
I am using the High Seat (Bench Type). I bought a High Comfort Seat, used it once for about 2 hours and HATED IT.
Eddie F.
I LOVED my '07 R1200R
I LOVE my 2010 R1200R
BigEasy
Post by BigEasy »
dbrick wrote:We're in Centralia WA, on our way south from Rich's, where Rad (R1100S) and I went for new seats. Here's the R12R outside the motel:
Dave, that looks awesome! Sounds like you're happy. I hope you think I steered you in the right direction. Good roads my friend. Keith
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
parkec
Triple Lifer
Post by parkec »
Stock, with a bead rider.
Cooler in the summer, let's rain run down under you. Not too comfy after 8 hours or so.
Really would like a heated seat.. I'm running naked. Gets cold!
IBA #50026
xcell1600
Post by xcell1600 »
I have a comfort seat for a 2009 R1200R I would like to sell. Part number 52537721958. $400
Send me a PM if you are interested.
rockbottom
Post by rockbottom »
eddiepat62 wrote:I am using the High Seat (Bench Type). I bought a High Comfort Seat, used it once for about 2 hours and HATED IT.
I was surprised at how long it took my Comfort Seat to break in. Much longer than the stock one.
BoiseBiker
Donating Member #: 969
Post by BoiseBiker »
I replaced the stock bench with a high comfort and would not go back. It's just a hair taller so easier on the knees. Feels more like a cruiser seat to me. I can see how I would hate it on the track or off road, just because it's wider.
I'm selling the old standard stock seat for $250, just PM me. Perfect shape.
2009 R1200R
2007 Triumph Rocket 3 (Good golly, way powerful and comfy. You must try one)
