Fuel line quick disconnects
dwheels
Post by dwheels »
I just changed the one of the old plastic ones to a new metal one and now bike doesn't seem like getting enough gas. I have to keep idle on high or throttle up to keep running otherwise it shuts down after a couple seconds. It really has a hard tome starting...any thoughts...HELP.
R1150Rclean
Re: Fuel line quick disconnects
Post by R1150Rclean »
dwheels wrote:I just changed the one of the old plastic ones to a new metal one and now bike doesn't seem like getting enough gas. I have to keep idle on high or throttle up to keep running otherwise it shuts down after a couple seconds. It really has a hard tome starting...any thoughts...HELP.
Did you knock the throttle cable out of its seat?
dwheels
Post by dwheels »
NOT SURE, HOW WOULD I HAVE DONE THAT AND HOW WOULD I KNOW?
THNAKS
Donating Member #: 312
Post by boxermania »
dwheels
1) The quick disconect might not be fully engaged. There is a chck valve inside that is actvated when both halves are fully engaged. Separate the two halves, place a little lubricant on the o-ring an assemble until that release tab snaps.
2) Check the right throttle cable by the quick connects, it is suposed to fit inside an adjustable holder. It is not uncommon to pull it out of the holder while working on the quick connects and that will make the engine do what you are experiencing. Pull slightly upward and slide into the holder.
dwheels
Post by dwheels »
That worked! I just reset throtle cable in sleeve. THANKS!!!!
fpgirard
Post by fpgirard »
Proof positive that supporting this site is worth every penny. This would have been a $100 fix at my local BMW dealer.
p
2003 R1150R
1995 K75 (sold)
