how much brake fluid ?
babulin2002
Post by babulin2002 »
Hi to all,
Silly question, how much brake fluid should i get in order to bleed the brakes on my 94 R 1100R ?
Found all the info how to do it etc, but not how much fluid it actually takes. It has been bled last time about 2 years ago, and it is brown and low in the reservoir, high time for a change :)
Thanks !
cheers
boxermoose
Re: how much brake fluid ?
Post by boxermoose »
ABS or Non-ABS?
TANSTAAFL
babulin2002
with abs
boxermoose
I think a pint bottle is sufficient but I'd get 2 - if it remains sealed it should by OK for your next bleed if you don't use it/open it
Incase you need instructions - see below
http://www.ibmwr.org/r-tech/oilheads/brakes.shtml
TANSTAAFL
babulin2002
thank you !
