optimum shift rpm
redwing
optimum shift rpm
Post by redwing »
What is the best rpm to shift at? I saw a review about the Honda VTX1800. The review suggested the best rpm for shifting the VTX is when the power curve flattens out. I think the motor had maybe another 1000 rpms before it red lined. I have seen two or three different power curves for the R1200R. So, what is the best rpm to shift at for max acceleration?
Also, I just realised that I have not been using all of my throttle under hard acceleration. So, my bike is even faster than I thought. 8) How light can the front become under full acceleration?
08' R1200R
Sweet...
bobw
Re: optimum shift rpm
Post by bobw »
Just learn to feal the engine when it passes it's peak output or the rev limiter will let you know :lol:
The front end can be very light in 1-2 gear.
I would have to agree that just before the limiter kicks in is the best place to shift. YRMV. 8)
If you let it bounce off the limiter, you can just quick shift without the clutch or removing any throttle if you time it right...
Then again, you shouldn't listen to anything I say really.
celticus
Donating Member #: 548
Post by celticus »
Mine is not noticeably light in any gear under hard acceleration. Maybe I just don't notice it. It only comes up if I make it.
What is happening to my skin?
Air can hurt you too
redwing
Post by redwing »
Thanks for the input.
I think I'll put it in second and run it up to near the red line so I can get the sound of the motor at the shift point. I can't seem to be able to take my eyes off the road under hard acceleration... but that's probably just me. The bike sure pushes you back in the seat ... it's fun. Thanks again.
Robert
08' R1200R
Sweet...
celticus
Post by celticus »
"I can't seem to be able to take my eyes off the road under hard acceleration... but that's probably just me. "
That sounds like good policy to me.
bobw
Post by bobw »
+1. If I am riding at or near my and/or the bike's max, the last place I am looking is down. :lol: This bike is so quiet and smooth that it can get you in plenty of trouble as those qualities help make her sneaky fast (tech term). All the electronic BS in the world will not replace well practiced and competently applied skill sets. Get to know her a bit and then ride her like you stole it.
Cheers
papasong
Post by papasong »
Hi all,
Along the same lines... I'm curious what R1200R riders consider to be "optimal cruising" rpms, in any given gear.
I may not be asking the question in the right way. Sorry.
On my last bike (F800ST), I tended to keep the rpms around 4500, on average (3rd gear an up).
I'm still new to the R1200R and learning what feels good on the bike.
Thanks,
Jeff
Current: 2009 R1200R Night Black
Past: 2008 F800ST Graphitan
Lifer #864
papasong wrote:Hi all,
Thanks,
Jeff
Anyplace from around 3,200-4,600. There is a slight buzz point in some gears right around 4,000, so I tend to avoid that.. but I've also been known to go 20-30 miles at 80MPH in 5th because I didn't realize I was in 5th and the engine is just so darn smooth..
Run it where it puts a smile on your face. You're happy - it will be happy.
papasong
Post by papasong »
Thanks, Don.
Sounds about right.
Yeah, the engine is REALLY smooth in 5th at cruising speeds. I have to remind myself sometimes that I have that 6th gear to bump up to once I'm up to highway speed.
Lifer #864
snag
Donating Member #: 639
Post by snag »
Don,
"Run it where it puts a smile on your face", that sums up a book full of technical data, ride reports and analysis. Experience makes life simple. That said, "ride it like you stole it" is pretty darn good advice as well.
Doug
Plea bargaining does have its advantages.
'08 12R
'79 CBX
'74 CB750
Catchina
Donating Member #: 998
Post by Catchina »
Good info for a r1200r noob in this thread. Any updates to this topic for the 2011 with updated engine? The rev limiter is set to 8500 rpm, is it a good idea to take it near that before shifting? I have close to 3k miles and may have been shifting too conservatively at 5k to 6k rpm. Is this bad for the engine?
2011 R1200R RED
1996 Virago XV 750
ContraMoto
Post by ContraMoto »
redwing wrote:So, what is the best rpm to shift at for max acceleration?
From a physics persective, you need to apply force over distance and time to accelerate continuously (F=mA is only an instantaneous measure). Force over distance and time is power, or work rate. Force is torque on a rotating system...torque times rpm equals power.
Max sustained (ie, a few seconds) acceleration of the bike will occur at maximum power. On our bikes, maximum power is right near the redline.
'07 R12R Black w/stripes
North Cali
jkhomes
Donating Member #: 939
Post by jkhomes »
The boxer twin is a very versatile motor. You can run it at high rpm's and have lots of fun, or shift more conservatively for better mpg (and still have fun). Some days I find myself using 6th gear more than others and running higher revs. I doubt if shifting at higher or lower rpm's will affect the engine.
John K
2008 R1200R
2013 HP4
famousperson
Sextuple Lifer
Donating Member #: 599
Post by famousperson »
redwing wrote:What is the best rpm to shift at?
I'd been tempted to ask that question for a long time, but was sort od embarrassed to, 'cause I figured that I should know the answer intuitively. It looks like I am conservative. I seldom come close to the red line, probably habit from my low-revving/vibrating English bike/Harley Sportster days. I find myself up-shifting at ~5000, possibly 5500 at times (like when getting on a freeway). I down-shift at ~3200 - 3500. The bike lugs badly below that (you can start up in second, although I hate to think what I'm doing to the clutch when I accidentally do).
Most of my riding has been in the city, where over 4000 is kind of noisy and rude, so that's the point where I cruise. When I'm on the open road I don't pay attention, although like others I have to remind myself to shift into 6th at highway speeds.
Peter
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
jkhomes
Post by jkhomes »
Noisy and rude? Doesn't sound like a BMW at any rpm's...
John K
2008 R1200R
2013 HP4
famousperson
Sextuple Lifer
jkhomes wrote:Noisy and rude? Doesn't sound like a BMW at any rpm's...
:) To my ears, anyway, being on the bike with the helmet visor open. I don't know what it actually sounds like from the sidewalk.
'07 R1200R
Life Member #599
ipokebadgers
Donating Member #: 913
Post by ipokebadgers »
I don't know where everybody rides where they can run it to red line or to the limiter before they shift. I usually don't pay attention to the rpms I just shift where it feels right and that spot has been different on every bike I have owned. That's the way I have done it for 30 years. My first bike didn't have a tach and my second one didn't have a tach that worked.
Today I watched on my way to work and I find I am shifting around 4500 rpm. I got out of town and ran it up to about 7K in 2nd gear and was doing 70+ and 3rd gear was really getting up there. That isn't good in town as I would be getting performance awards everyday. So, where do you guys ride that you can red line it before shifting?
2000 K1200LT(Gone)
1978 R100S (Gone but not forgotten)
ContraMoto
ipokebadgers wrote:So, where do you guys ride that you can red line it before shifting?
I don't think anybody is saying they actually do that. Redline would be where you would shift for maximum acceleration. In theory.
In practice, most people shift the same -- 4-5k.
North Cali
ipokebadgers
That makes since. I am a moron.
2000 K1200LT(Gone)
