Latest Farkle.. Flash2Pass
http://www.f2ptechnologies.com/category/200/
Added it to the auxiliary lights. Now a quick two flash of the lights opens or closes my garage door. Also added a transmitter to my M3 - which lacked a built in garage door opener.
Works quite well.. will post one or two pics when I have a chance.
- Lost Rider
Re: Latest Farkle.. Flash2Pass
List price is $79 for the basic kit (receiver and one transmitter) - extra transmitter is $34. I got'da'deal.. $100 delivered for 2 transmitters and one receiver. Works great.ChiTown wrote:I like the idea of that farkle, how much did it cost?
The transmitter is the square black box right next to the starter relay (below the preload adjuster..) Small enough to tuck inside the headlight shell probably if you wanted to tie it to the high-beam.
...how are all these gadgets held onto a bike....double sided tape, velcro, dirlling holes and screwing it down?
also, what if you ride in the rain and some water gets under the seat?
just curious....thx.
Alex G. - San Francisco Bay Area - Member # 642
08 R1200R
07 GSX R600 - Totalled by EX SO
08 R1200R
Tie-wraps mostly. The fusebox is screwed to the fender. I don't get a lot of rain under the seat since I have a hugger - which keeps the stuff thrown off the rear wheel out, and the seat wraps over the top joints so rain tends to just run off. I get more dust there than anything..Graf wrote:...how are all these gadgets held onto a bike....double sided tape, velcro, dirlling holes and screwing it down?
There's also ne available from Autoswitch that ties into the turn signal cancel button.
Cycle Gadgets
http://www.cyclegadgets.com/Products/pr ... p?Item=ASG
Cycle Gadgets
They had this for earlier BMW's also.. the downside is - it requires your remote and modifying your remote.. and like most remotes, mine has a battery in it that I forget to change. Nice part on the one I got - it's powered right off the bike. No battery to go bad, and I can save my remote for SWMBO..maduko wrote:There's also ne available from Autoswitch that ties into the turn signal cancel button.
Cycle Gadgets
famousperson
- Sextuple Lifer
SWMBOdeilenberger wrote:They had this for earlier BMW's also.. the downside is - it requires your remote and modifying your remote.. and like most remotes, mine has a battery in it that I forget to change. Nice part on the one I got - it's powered right off the bike. No battery to go bad, and I can save my remote for SWMBO..maduko wrote:There's also ne available from Autoswitch that ties into the turn signal cancel button.
Cycle Gadgets
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
Life Member #599
She Who Must Be Obeyed - from Rumpole of Bailey Street..famousperson wrote:SWMBO![]()
