Gear Lubes
Posted: Fri Apr 06, 2007 10:46 am
Can anyone tell me the difference, if there is any, in SAE GL-5 75-90 Gear Lube and SAE 90 Hypoid Gear Lube?
I was reading over the bikes recommendations for gear lube for the tranny and final drive. It says to use SAE 90 Hypoid Gear Lube GL-5
My Toyota truck says to use 75-90 Gear Lube in the transmissions and SAE 90 Hypoid GL-5 in the rear drive.
I was just out at Advance Auto parts to see if they knew, but they only had "Marine" Hypoid Gear Lube in a plastic tube, like what calk compound comes in.
Posted: Tue Apr 10, 2007 6:44 pm
by Beemeridian
576
Posted: Tue Apr 10, 2007 8:32 pm
Thanks. I figured as much. I've been reading some other things on the internet about hypoid gears etc. and their requirement exceeding transmission gears. Then I ran across several articles stating that synthetic GL-5 75W-90 would work just fine in both the tranny and differential. So I picked up a few quarts tonight at Wally Mart and tomorrow or sometime soon I'm going to change out that stuff in my little truck.
