Clocks...
Posted: Mon Oct 16, 2006 2:41 pm
by \\Mike_Lea//
As the nights are drawing in, I noticed that one (or maybe a couple) of the backlights on my Rock have given up the ghost :(
Zero - 60/70 is quite clear, but the rest of the clock is a little dim. Not the end of the world, but it's really distracting when I glance down at the clock, and is a bit annoying really :x
So... Anyone dismantled/replaced them? Easy/Difficult/Impossible?? Any help warmly received!
M :D
Posted: Wed Oct 18, 2006 7:37 am
piece of piss. ;)
eyebrow pops off (regrease the lugs and grommets when you reassmble otherwise you'll pop the grommets out)
undo the two screws either side, then unclip the three clips holding the clocks to the backpiece: these need a bit of figuring out - but any clever person should manage. ;)
then the bulbs should pull out from the back of the clocks fairly easily. :)
Posted: Wed Oct 18, 2006 1:18 pm
by \\Mike_Lea//
That's what I like to hear !! I'll have a crack at that this weekend; For a (ehem!) intelligent person such as I, shouldn't be a problem :wink:
Mike
Re: Clocks...
Posted: Thu Jun 13, 2013 3:00 am
by Lob
Can anyone confirm if the Rockster has only toplighting for the display?
And RB, if not, how do you get those 3 clips off the back of the cluster in order to access the lower bulbs?!
Re: Clocks...
Posted: Thu Jun 13, 2013 4:45 am
Lob wrote:Can anyone confirm if the Rockster has only toplighting for the display?
The Rockster's clocks should be fully lit.
Haven't been in there for a while, but the assembly is a little odd - iirc you have to pull the clocks unit away from it's mounting at a 90 degree direction to the one you think it should go - or something.
Re: Clocks...
Posted: Thu Jun 13, 2013 10:25 am
by Lob
those 3 frikkin clips.......you somehow wedge and push?
I think my top lights are lit but the bottom ones, if they exist, are not.
And I thought as I pulled it apart "why grease the grommets" and then spent 10 minutes fishing two of them out :D
Re: Clocks... Rockster gauge backlight
Posted: Fri Jun 14, 2013 12:48 am
The spring clips "grab" a circumferential groove at end of each mount post. The clips are removed by pushing at the flat/upturned side to slide the clip across the post end. It's simple once you get the first one off and see the clip construction. But that first clip is a bitch.
There are four backlighting bulbs, two for each gauge, positioned at wacky angles.
I changed my backlight from the OE incandescent bulbs to LEDs. Not better, just different.
Some of the rubber bulb sockets were easy to remove, and others near impossible.
Re: Clocks...
Posted: Fri Jun 14, 2013 6:12 am
by Lob
BINGO!!! So easy, rather than push down on that thing just lift it up!!!!!!!!!! AHHHHHHHHH!
What type of bulbs are they, I appear to have one not working.....and will of course go LED and coloured as I'm tacky :D
Re: Clocks...
Posted: Fri Jun 14, 2013 8:08 am
Lob wrote:BINGO!!! So easy, rather than push down on that thing just lift it up!!!!!!!!!! AHHHHHHHHH!
I 'think' they're a fairly common bulb.
(unlike the frigging number-plate bulb).
Re: Clocks...
Posted: Fri Jun 14, 2013 8:36 am
by Lob
I just ordered some T5 bulbs from ebay for a quid per pack. One of 2 and one of 10.
From the measurements, it looks like they will fit. I am one bulb down so I can test bulbs by just pulling the beak off ;)
News later this month when they arrive.....
Re: Clocks...
Posted: Mon Jun 17, 2013 12:17 pm
Fwiw, this ADV topic was my inspiration for Rockster gauge lighting with LED "bulbs":
http://www.advrider.com/forums/showthread.php?t=710657
Re: Clocks...
Posted: Tue Jul 02, 2013 3:18 am
by Lob
When I said this month in June, I really meant this month in July :D
eBay delivery from China is not the quickest :badgrin:
Re: Clocks...
Posted: Mon Jul 08, 2013 1:52 pm
by Lob
ok, these little gems arrived and are installed....
http://www.ebay.co.uk/itm/120869736985? ... 1497.l2649
looks nice, lights up the clock in blue too. If they don't light up, turn 'em round!
pics to follow once it's dark.
Re: Clocks...
Posted: Tue Jul 09, 2013 3:02 am
by Lob
Re: Clocks...
Posted: Thu Jul 11, 2013 4:48 am
Lob wrote:Image
Woaah! interesting - let us know what it's like to ride with them.
FWIW I always find the rev counter impossible to read at dusk and under yellow motorway sodium lights.
Re: Clocks...
Posted: Mon Jul 15, 2013 3:22 pm
by Lob
gut feeling, RB, is it's an improvement. More light, better colour for night reading. I'll confirm.....and I have a spare set I could let you have.
Re: Clocks...
Posted: Tue Jul 16, 2013 3:20 am
Lob wrote:gut feeling, RB, is it's an improvement. More light, better colour for night reading. I'll confirm.....and I have a spare set I could let you have.
That's most kind of you! But personally I'd just keep them as spares if I were you. :)
Re: Clocks...
Posted: Thu Jul 18, 2013 2:27 am
by Lob
that's a shame, I had them pencilled in as your wedding present!! ;)
Re: Clocks...
Posted: Thu Jul 18, 2013 8:08 am
Dang! ;)
Re: Clocks...
Posted: Tue Apr 22, 2014 11:13 pm
by 5lv
I switched to these LED's on my FZ1 and it helps if you rough up the end with some sand paper or whatnot to help diffuse the light. Be careful with the type where the LED is sitting right on the end, you can still do it, but go gently.
