R1100R Headlamp Question
kbullen
Post by kbullen »
This morning I noticed my hi-beam is out. I hit the autoparts store during lunch and found the right replacement, but before I tear into this, I was reading the manual and they say to disconnect and insulate the ground from the battery.
I assume is the small, "3rd" wire connected to the battery posts? By insulate do they mean make sure it doesn't touch anything else while it's disconnected?
It seems pretty straight forward, I had the headlight apart looking at it (and it didn't fall apart going down the road after lunch), but I don't want electrical problems.
Kazushi
Re: R1100R Headlamp Question
Post by Kazushi »
I'm not sure what the directions say, but it's sensible common practice to take the battery offline before you start working with the electrical system. This would include bulb replacing tasks...
kbullen wrote:This morning I noticed my hi-beam is out. I hit the autoparts store during lunch and found the right replacement, but before I tear into this, I was reading the manual and they say to disconnect and insulate the ground from the battery.
BMW Riders Club of Greece
http://www.bmwriders.gr
NoRRmad
Donating Member #: 388
Post by NoRRmad »
...So you have to take the tank off to replace a headlight bulb???!!!
TX2Step
Post by TX2Step »
NoRRmad wrote:...So you have to take the tank off to replace a headlight bulb???!!!
No, you don't have to take the tank off (this is an R1100R we're talking about). Take the rider's seat off and the battery terminals will be accessible.
NoRRmad
Post by NoRRmad »
:oops:
